Timing ECU Question
QDM
Phoenix, AZ
I just put a new distributor in my 80 and I need to set the timing. I put a paper clip in the E1 and TE1 terminals but I can't get my CEL to blink. If anyone has any insight it would be much appreciated.
I made a jumper wire with pins on it, it has always been hit or miss with just paper clip, also make sure your not using a insulated paper clip or plastic one
  • Like
Reactions: QDM
The CEL does turn on the bulb is good. I'll try making a jumper wire when I get home. Thanks for the help.
Here is what I made wire with pins crimped on both ends
I ended up just tapping the harness and adding an in cab switch so I can check any CEL without popping the hood. Works great.
