Probably a dumb question...
When reinstalling the pulley, what type of lubricant do you use for the seal?
If by oil slinger, do you mean that concave disk that sits in front of the small cog on the crank? Mine has that too. Not sure how it could be rubbing. How did you know that was robbing in the cover? If you could see wear on the back of the cover, mine seems pretty pristine.If I recall, mine has a metal oil slinger that goes on the crank before the cover, it rubbed slightly on the cover. I had to work on it a little to make it stop rubbing.
Hmmmm. Was the noise a squeal or something more mechanical and metal sounding?Yes, that concave disk. If I recall, it made some noise. I don’t remember what it was rubbing on. Maybe the crank gear. I think I had to shim it.
Yes, I'm loosely installing the cover before the pulley is in place. My first try was pretty wonky. Took too long, used engine oil to lubricate (which seems to have been an OK thing to do). Regardless, I'm not too confident about the first attempt. I was more careful the second time. Not sure why it's squealing. I do have two minor (very minor) grooves worn into the pulley nose ... towards the block end. I can't be sure, but I don't think these grooves come into contact with any sealing surface. I'm pretty sure they were caused by messed up attempt #1. I'll post a picture here. Maybe someone can see something obvious that I'm missing. Oh, during try #2, when I took the cover off, again, it was nice and wet on the inside. I was worried oil wasn't making it's way into that area. Don't think that's an issue. I am using 20w50. Maybe it's too thick to lubricate the seal. Seems silly, but I'm grasping at straws.I lube lightly with wheel bearing grease. Are you loosely installing the timing cover, installing the balancer and then tightening timing cover bolts? If not, the seal can be misaligned with the balancer. If you are doing that, disregard.
I've been curious about that notch in the slinger. This is the slinger on my 74 F.5. The notch doesn't engage with the crank gear keyway.Could it be possible the notch in the slinger came off of the crank gear keyway?
