Timing chain need attention?
NJ SUCKS
Website
www.recordme.com
I’m searching to see if I need to think about my timing chain my truck is getting close to 300,000 miles runs great I don’t wanna push my luck. Probably a dumb question but are chains lifetime or do they need to be replaced? Also is this an interference or non-interference engine?
Thanks
I do not recall which years had faulty timing chain slippers. Do a mud search. If you fall within those years, your slippers will most likely fail before your chain. If you need to replace slippers, might as well replace the chain.
Non interference. If your engine is running great then don't worry about the chain until you need to rebuild the engine.
Thanks I appreciate you taking the time to fill me in
Thanks appreciate your help
Timing chain tensioner is part of the equation, doesn't hurt to clean, inspect, or replace. IME it can get gummed up with varnish. FWIW
Unless you are hearing sounds from the timing chain area .... then I wouldn't give the timing chain another thought.
It is extremely rare to hear of timing chain issues. While it is a good idea to replace one at the time the engine is rebuilt, most will still be 'in spec' even then.
Now...IF a slipper or damper were to break/wear or the hydraulic tensioner fail...that would be a different story, but again not common.
The timing chain is NOT to be considered a maintenance item. If your engine is running well now, it might well go 400K or more before needing attention.
Mine has over 300K still runs great and has over 190psi compression on each cylinder. It leaks oil from various places but aside from that...is working fine.
Very helpful,thanks!
