Timing Chain Cover Removal
San Diego, CA
So after two days of wrenching I now have leak free oil pans. Problem is they weren't the ones leaking. So now feeling super stupid, I need to take timing chain plate off. It looks like mixed reviews on if the heads should come off or not? Is there anything else I should look at or replace while Im in there? Thanks
i will try. It seems to be behind a pulley. Rite above were the square hole from were the oil from pan one and block meet.
Good chance that is the crank seal leaking. Just need to remove the crank pulley and pop the old seal out and a new seal in. Common source of leakage. I have replaced a bunch of them recently. John
I also have an oil leak coming from the back of the timing chain case. I was told it's a 20 hour fix and the head must come off. A quicker and easier method would be awesome. Please post pics!
And if it does?
Then you probably have a leaking oil pan arch or rear main seal both of which are very labor intensive fixes. I'm pretty sure my pan arch leaks but its so slow Its not worth the effort.
I have replaced the three upfront seals mentioned and just noticed an oil leak which is trickling down onto the lower passenger side radiator hose, the end which is away from the radiator and which sits above a little narrow metal brace. So frustrating! I have to take off the under radiator cover and clean it up to diagnose.
Absolutely sure it's the engine and not power steering or something? Have you UV dyed the different systems to ensure your leak is from the engine?
I cleaned mine up pretty well and am now watching daily to identify the path of flow for what looks like engine oil, not ATF (PS fluid). I like your UV dye idea, though. That is very clever and I will use that if I need further diagnosis of the problem. Thanks for the tip.
