I posted in here a while ago about my 2F in my FJ40 running poor. So far I've tested vacuum, compression, adjusted the valves, swapped carbs(for test purposes), still no change... so I am focusing my attention on the timing and ignition system.
Basically it starts up great, idles great, when you get on it and go up through the rpm range there's very poor power and it backfires back up through the carb and also out the tail pipe. The main barrel on the carb is just black from carbon.
My question is this: Can you assemble a 2F with one tooth off on the timing gears and get these results? Can you put the distributor in 180 degrees out and it still run but just really s***ty? I know for a fact that the previous owner had to assemble the engine in a hurry to get it so I could pick it up, and since he was selling it his only real requirement was that it ran, so anything could be possible.
I have been chasing this problem for 3 months now, I could really use some good feedback, maybe someone with a similar experience knows something?
Let me know!
Thank you.
Let me know!
Thank you.
