Throttle stiffness
east coast Canada
How stiff is your accelerator peddle? My Peddle seems quite stiff to push, however it feels very easy to move when disconnected at the TB. Most of the outer covering is gone, I am comparing it to my 2010 4Runner, drive by wire, which I hate.
It does not stick in anyway however.
TB does not bind either.
I would pull it and examine it prior to replacing it, see how it feels without the mechanical friction of the throttle body and pedal. If the cable feels fine, look at the pedal and other points of pivot. Make sure its not bending to sharply as well. I replaced mine after really hating how the sheathing had deteriorated and some of the MUD pressure around here to just replace it, but honestly, I could hardly tell a difference. In hindsight, I would have probably just dribbled some lubricant into the cable and worked it a bit followed by some heat shrink on the outside to get it looking good again:meh:
Mine had only 150k miles, but the Arizona heat deteriorated the sheathing. Then all the sand and dirt got into the cable. Game over from there. All the lube in the world wouldn’t fix it. I had my dealer throw one on while I had it in for service, it was a night and day difference.
Compared to a modern Japanese car, I find the 80-series throttle to be stiff--even after installing a new throttle cable. There should be not stick, but it's not going to feel like a Lexus either.
It might be your kick down cable. My pedal was stiff. Replaced it with OEM. Didn’t make a difference. Lubed and adjusted the kick down and made a big difference. My foot and ankle don’t get tired anymore.
