Throttle return spring question
Ohio
Hi. The PO of my fj40 connected this piece to the second bolt on the valve cover, like below. I think it's called the throttle return spring, but I'm still learning and honestly don't know what it really does. I just replaced the old valve cover to the newer aluminum cover and looks like this method may not fit there anymore. Where would y'all recommend connecting it to?
View media item 81360
What carb is that?
Or is it on backwards?
That carb sits on an Offenhauser manifold....seem to recall Offenhauser 2F retrofits were available once upon a time?
It's a 74 F.5 engine with a 2F valve cover and a Weber 8867 carburetor. I don't know how to tell if it's backwards :confused:
Are you running cable or rod linkage?
Let’s see the backside of the carb; the side that faces the firewall.
You should be able to utilize one of the inboard mounting bolts (facing the head) to anchor a bracket similar to the 2F choke holddown for the other end of the spring.
as long as i have Marks blessing on this concept idea i just came up with , we may have a Factory-Focus-point-
mindset-solution
? .........................Maybe
i have both a Left & a Right hand side
- to be clear this will get sandwiched between the valve cover nut and grommet
NOT between the grommet and aluminum cover itself
- the hole in the bottom is wide enough for the valve cover nut outer shaft OD
- it sits up high enough so the spring at a angle going down clears the valve cover
- small hole on top outer portion for throttle return spring hook
- lets call it a " standoff " for now
- its a factory toyota part also ..............if u were thinking otherwise for any reason ?
That looks like edelbrocks’ newer equivalent of the carter AFB (4 barrel) carb. And because of that offy manifold for Toyota the carb is mounted sideways (90-deg) compared to SBC applications - edelbrock label points forward on manifold. On my SBC’d 40 with a carter AFB carb that return spring simply mounts to a bracket on one of the top water pump mount bolts. How’s your throttle cable mounted, off the driver’s side fender/apron?
I agree with the way that the PO positioned the carb, not having two primary barrels heavy on the 1-2-3 side of the manifold and the logo positioned to the front. But possibly flipping it 180* so that you might do a Weber-style spring mount off of the nuts of the studs if the valve cover is in the way; that is if you can get throttle linkage in there still.
You bring up an interesting question by inference. Assuming the carb was designed with a forward orientation, I wonder what effect a sideways mounting has on the ability of the float to open and close properly and whether it would face potential flooding or starvation in sidehill situations off road.:hmm:
Got it ...........
