three on a tree
Orlando, Fl
well, my column shift is going out, its stripping the bolt that connects teh shifter to wheel. is there something i can do to stop this from happening? because if this goes out im gonna try to put a 5 speed in, but im not able to spend that kind of money yet.
thx
Jonathan//SandRider
take it to ammco transmissions. they are everywhere and will give all transmissions a free inspection and they are REALLY accurate.
While I agree that the J30 tranny is not the most ideal for a lot of situations, and a 5-speed would be sweet, there's no reason to rush into the swap just because your shift linkages are worn out.
Column shift parts shouldn't be that hard to source either free or cheap if you want to keep it. I basically gave all of mine away.
Or convert it to a floor shifter. You should be able to find the parts for under $50; you just need a shifter cane and the top cover off a floor-shifted J30. The hardest part of the whole swap is figuring out where to cut the hole for the shifter.
yup a nice 3 on the tree is really fun and I like mine
bull said:
I like my 3 on the tree.. Look at the bright side; it can be used as a theft deterrent. That being said ping cdan and sor to see if you can source the parts.
A turn-key H55 will cost about $4000. Surely there are other mods that will give you greater bang-for-the-buck.
