I did a compression test today on a new-to-me 1996 FZJ80. Results are not good. I live at about 6,000 feet, so I adjusted the readings accordingly. But cylinder #3 doesn't look good. I put a little oil in it and it came up some, but not to the level of the others.
#1 - 181
#2 - 181
#3 - 84 (108 wet)
#4 - 181
#5 - 175
#6 - 169
So, I might have a valve issue on #3 or something. I have no misfires, and no CEL - the truck seems to run fine. The #5 and #6 being low means maybe the HG? - if I understand correctly, the HG tends to go out there first? The truck cooled down a bit before I tested the last few - I ran up and bought a different compression gauge to cross-check the one that I was using. That could also be why #5 and #6 are low.
There is a little smoke on startup - even when warm. PO said he didn't lose coolant. There is a crack in one of the PCV hoses, and the plug seals have never been changed - so I thought maybe that is where the smoke was coming from.
Coolant level is full currently, but the coolant sort of looks like garbage - looks like they swapped in the green stuff at one point. But it doesn't look great. I see no white/milky residue on the dipstick nor under the oil cap. I will send in a sample for some analysis and see what comes back.
Do you think this is just a valve issue?
Here are the spark plugs - #3 doesn't look that different. (#1 to #6 left to right below)
#1 - 181
#2 - 181
#3 - 84 (108 wet)
#4 - 181
#5 - 175
#6 - 169
