Thoughts on 2007 head and direct ignition
Simpsonville,SC
1993 FZJ80 with 315,000 miles - starting to gather parts for overhauling the 1fz-fe.
Has anyone swapped in the newer head with direct ignition? Can it be done, or is the short block significantly different? It seems like it should be plug and play on my older, less complicated truck. Would it be simpler to order a rebuilt long block from Oz? It looks like the power upgrade is decent.
Was also considering the A750F but the threads on that - no thanks. I'll keep the bus tranny.
Search has yielded little else, but perhaps the wrong terms were used. Searched direct ignition, 105 to 80 1fz-fe and related variations and permutations, 1fz-fe A750F.
Thoughts? Warnings?
Edit: meant title to read "...1998-2007..."
I doubt you can put the newer head on your block. Nothing to signal the ecm to fire the coils. The distributorless engine has a crankshaft trigger where the USA 80 use the sensor in the distributor
Yeah you are missing a lot of the requirements to run the later head, like Rivman said you are missing a crank trigger, the cam sensor is not in the distributor since there isn't one. Your ECU would not know what to do with the signals even if you had them. You could run a stand alone.... But I don't think that is the route you wanted to go?
I'll take a supercharged 5 speed
Ok thanks. So probably much simpler to just order a long block and harness from Oz or South America or somewhere that got the updated design.
Thanks everybody.
I have the new motor in my 100 series and I've heard of people swapping the new engine into the 80 series here in the uae so it is possible.
Also for the transmission, all the 100 series with the 1fz use the A442F or the 5 speed manual.
Do you have a link or remember the title of the post?
No direct experience, but you will need the ecu, harness, ignition parts, fuel pump, etc.
Direct injection and distributorless ignition are good things, but it's not a minor job.
The injection pressure is much higher, and the timing of injection events is more critical (iirc)
  • Like
Reactions: ppc
I don't remember reading anywhere that it was direct fuel injected. It does have different fuel injectors and direct IGNITION
whoops. you're right.
I still think you'll need the ECU
