This is what happens when.....
Sad Day!
For the trans to be broke all the way around are you sure something didn't let lose inside and lock it up?
Quite possibly GRB. I think we'll be able to tell more about the damage once the tranny is out of the truck and we can take a look at it and inspect it.
I'm wondering how much of the shock from a drive shaft spinning freely at 2600-2800 RPMs could/would be transmitted through the casing of the tranny.
We'll once we get it out.
Best.
-onur
Ouch. I feel for him.
I had a driveline vibe a couple years ago that I could not find. Two Toyota techs at different dealers checked it and pronounced the driveline fine. The thought they starter plate was the problem.
I removed the rear shaft, vibe went away. When I got the joints out they looked just like the pics above.
I can see how lucky I was now..
BTW, Beno, you sound like an acceptionally good friend. :cheers: :cheers: :cheers:
I had some vibes coming from the rear u joint on the rear drive shaft. I lubed the joint every time I changed the oil from the time the DS was new. Interestingly when I removed the u joint one of the arms was completely dry and had no needle bearings. The other 3 arms on the joint were lubed fully. The journal for the dry one must have been plugged, (from assembly??) . Just a heads up that I don't know how to prevent. The moral of the story is replace u-joints as soon as the start acting up.
Cheers,
Sean
That looks terrible.
I think it should be pointed out that a lot of folks who are not mud members, but drive land cruisers have a mentality that since they paid so much for such a legendary machine, it should never break down. I have heard that before. They seem to think that taking it in for an oil change is maintenance. I will keep these pictures handy to show them that more than an oil change is required.
If that was the case there would be more damage and both driveshafts would probably be involved. There is more than enough stored energy in that shaft spinning at ~3,400 RPM to do that much damage.
75 MPH with stock tires is roughly 3,400 driveshaft rpm.
uh oh...
for some reason, i thought that cruisers had that neat little cage/ guard around the front driveshaft like the mini trucks and 4 runners. i guess i just haven't been that observant crawling under mine. I'm very meticulous about maintaining my vehicles, and I think i might still build a d/s guard to prevent any issues that may come about. I've already had tranny issues this month that are still in the process of being taken care of. wouldn't want another problem. i'd rather do preventative maintenance.
Breno, I'm not dumping on your friend but,
What ever happened to greasing the truck during an oil change? I thought this was standard operating procedure and nothing out of the ordinary. I don't take my vehicles to get the oil changed but shouldn't the greasing be done also?
Is he doing the work himself or taking it to a service station?
Landtank - granted I've never own truck before, but this is the first time I heard that its a standard operationa procedures. How come not too many people talk about this?
Man, I am lucky too! I had a drive shaft let loose at 70 on me as well, but only one of the cups broke, the other held the shaft in place and really all I had to do was replace the shaft.
Same cause, neglected to grease that U joint for a long time.
Whew! I'm luckier than I thought I was!
From looking at the pictures my guess is that the failure had nothing to do with a trans failure, it was a victim of the carnage. When the joint failed the spinning yoke part on the transfer caught the loose driveshaft and forced it between it and the trans, there isn't room for it to fit, so something had to give and the trans broke.
If this theory is correct, it required a huge amount of force to crack the trans in half. If your going to reuse the transfer, very carefully examine the transfer output, the flange may be bent and/or the output bearing damaged. That bearing probably saw load much higher than design spec, possibly causing Brinneling, dents in the races and/or balls that will greatly shorten the life of the bearing. I would replace the output bearings while the transfer is out.
http://www.emersonbearing.com/fail_truebrinell.htm
It was more common back in the 60s and 70s as all the joints had grease fittings. And I mean all, tierod ends, balljoints, u-joints slip yokes. It was how a vehicle was serviced, everything got a squirt of grease while the oil drained.
Cars today don't have all those fittings anymore and I guess that practice has been lost, but it should still be done on every oil change. Our trucks are limited to just the u-joints and slip yokes of the drive shafts.
Besides the loss of money do to repairs, this is an incredible hazzard on the road. If you loose the front u-joint of the rear shaft it could get lodged in the asphalt and send the truck air born and really cause some damage for you and others around you.
If the driveshaft was torn up real bad I would agree, but I bet they'll find that there's another problem which caused this. I wonder if the engine died suddenly when this happen or he had to turn it off.
From my understanding of what happened, there was a large explosion like sound and tons of smoke. He limped it to the shoulder ASAP as it happened.
Like I said, I think a lot of the figuring out of what happened will occur once the tranny is out and we can take a look at it.
The xfer case seems fine so far. The shop was able to easily turn the rear drive shaft and the front output flange with the xfer in neutral and felt no binding, grinding, etc. But yes, I agree that the xfer should be looked over as well in this situation. We'll see what the owner decides. This is his DD and he needs this back on the road ASAP.
:D
oh boy!!
this is a godsend for all the fabrication junkies. Im already working on the "front driveshaft cage buildup"
word. everytime I run my 80 in the stadium events they make a fuss about my front drive shaft just hanging out ready to maim and destroy.:D
this was actually disproved on mythbusters last season :D
but then again it wasnt a lifted, cog altered, 80 series.
i guess this pictures worth about a thousand dollars instead of words. as bad as it is, glad it didnt snowball into even more issues.
off to lube the u-joints!
Beno-- you da man for all the help, hes one lucky friend of yours.
