Thinking about first 80 series
Hey guys I am thinking about getting an 80 series for a daily driver\out of state hunting rig. My main worry is about reliability. How do these things hold up? Most that I find for sale are between 200,000 and 300,000 miles. And the ones that I see for sale with less miles are two or three times the price. I am not adverse to turning wrenches but I don't want to be left stranded or have to spend more on the vehicle than than its worth. Can a 1fz be rebuilt resonably? What about the transmission how do they last? What should I look out for when I check out these rigs? Thanks for your help.
This question has been asked a few hundred times. If I were you, I would use "search" and read as much as you can, which would take you weeks, because everything you want to know is buried in this site.
The short answer is that you won't find a stronger more long lasting and reliable vehicle to serve your stated purposes. As with any old machine, maintenance history will determine its reliability and need for attention at the time of purchase.
When I bought our truck, I was running a Isuzu Rodeo that was closing in on 150,000. The 80 had just slightly more miles. Test driving the 80 was like getting in a nearly new vehicle vs the Isuzu, which had seen its day, but was clearly in decline.
The 1FZ is designed to run 300,000 before overhaul. Sure, there's the occasional head gasket, etc, but it's a strong motor that is more than up to the task. Sure, there's other stuff that can go wrong. Our truck has never left us stranded and I've done minimal maintenance in ~25,000 miles since purchase 6 years ago once I did the initial work of catching up on previous neglect and basic PM.
A good shortcut to much of what you're after can be found in the FAQ at the top of the first page here in the 80 Forum.
I wouldn't worry about getting a high mileage 80. Especially if the head gasket was replaced and head rebuilt. It will last for a long time.
Also the knowledge, writeups and support here on the forum is priceless!
As others have stated there's a lot of great information buried in this site, in the FAQ, and on Slee's website; Newbie Guide. So things to look at when buying a used 80:
Oil cap. Take it off and look for any signs of coolant. If wiped clean follow the next procedure and consider looking at a different truck.
Radiator and overflow. Green or red coolant? If red the truck has probably been cared for a little more.
While it's running and the engine warmed up watch the overflow container for any signs of bubbles. Give the throttle cable a pull to rev the motor. Any bubbles would indicate head gasket failure.
Oil leaks. Typically found around the oil pump seal on the front lower right corner and the distributor o-ring. Other places for possible oil leaks are rear main seal, valve cover, and oil pan.
Birfields. Are they puking grease or oil? This would up the priority of the axle rebuild.
U-joints. Just reach under the truck and give them a twist/wiggle to check for play.
Front and rear control arm bushing. Shine a flashlight on them and look for cracks.
These are just a few of the things I look at when inspecting a used vehicle for purchase. There's lot of great checklist on the web you can print out but these are some of the main 80 series items I can think of off the top of my head.
They are great trucks and very reliable. Take the forum with the grain of salt. People generally only post up problems they have. Many members are maintenance obsessed. If we all posted everyday about how awesome our trucks were running Woody would need to pay for a much bigger server. That said, this is a great community that I'm pleased to be a part of.
Mine has 310k miles and I'm celebrating by putting a turbo on it! They are very reliable if properly maintained. If not properly maintained, prepare to spend a lot of money to bring it back to life. I wouldn't hesitate to hop in my truck and go on a cross-country road trip. The "high mileage" of my cruiser is less of a concern to me than what type of beer to bring.
Thanks for all your help guys. I am going to look at one tonight. It sound like it may be in need of a new head gasket so I am not too sure about it but it is worth a look anyway. I apreshiate all the help I have gotten from mud over the years I have been a member here since 2002 but I never thought about an 80 untill I had my son last September. If this was a 40 I was looking at I wouldn't have any questions but 80s are all new to me.
Thanks for all your help guys. I am going to look at one tonight. It sound like it may be in need of a new head gasket...SNIP...I have been a member here since 2002 but I never thought about an 80 untill I had my son last September. If this was a 40 I was looking at I wouldn't have any questions but 80s are all new to me.
I'd never knock a 40 for any purpose, but an 80 is a more family-friendly vehicle. I had a friend with a 40 years ago who faced a similar issue. They made it work for awhile, but that was before the 80 series intro.
If suspected HG issues, there's a good point in making an offer that would make the whole project more affordable. Depending on whether you can do the work or not, costs will vary, but you'll have an immensely suitable vehicle once that's done. You'd want to check out the rest of the common issues still, but the HG is the typical major hurdle to owning an 80 -- real or imagined -- for most people and it's very repairable in most cases.
I think I was on here for about 9 months before I bought my 80. Just take your time and learn as much as possible, sometime be patient about finding what you want/feel is important in the truck exactly. I bought mine with 290k and have 311k now. Pretty solid so far.
I'm with greentruck. If you've got the time and space to work on it, an otherwise good 80 with a blown HG would be a great way to lower the cost of entry. :)
Plus the benefits of getting one with a bad head gasket is that it will be cheaper, and when you replace it you can replace most parts that go wrong with this vehicles and drive it comfortably knowing that is all good, it'll be like almost new.
Yeah I can do the gasket myself other than the machine work of corse I have done two or three head gaskets on my 40 over the years if that is the only thing wrong and i can get it for the right price we might make a deal.
Here's my take on this as a 1 year owner of a used 220K mile '97. With the miles and the years on the truck, basically everything rubber needs replaced. Suspension bushings are shot/torn/aged. Bearings are getting tired in axles,wheels, u-joints. Exhaust is tired. Interior is tired. All hoses are brittle and at risk of cracking/tearing, especially vacuum lines and stuff people don't replace with PM.
Good maintenance would keep things like head gasket, shocks, brakes, etc... at bay but it would take excellent maintenance or beyond to find that the deeper stuff has been done. If you go into it knowing you'll need to replace things beyond normal PM and do it 'just because' instead of waiting for it to break, you'll have a good time.
Hey guys I have another question for you? I looked at the truck and test drove it. Do these trucks usually accelerate pretty slowly? It seamed smooth but it really didn't push you back into your seat at all on acceleration. I have never driven one so I don't know what to expect.
Haha...no a naturally aspirated 80 will not push you back in your seat. It should accelerate much quicker than your 40 though.
The 80s with SC are surprisingly quick, but I think I can launch my Prius better than my 80. Low end grunt is pretty good IMO, but they are no track stars! I cruise mine in the 60-65 range on the highway.
