Things to do: trans-xfer case
SoCal
I've got the 4spd trans & xfer case on the bench, or what passes for my bench. Anything I should do to it before reinstalling, other than cleaning it up? It's got a TON of caked dirt, bit of oil, grease, & God knows what else on it so a good cleaning is a must. Is painting it a good idea? If so, what is good to use?
Vic
Redlands, CA.
Check the idler gear shaft and bearings in the Tcase and it they are bad, replace them. It is a high wear item. If you are careful you can pull the shaft out with the rear of the case pointing up and replace it without screwing up the alignment of the gear and thrust washers.
Vic, one MUST in my book would be a new imput shaft seal for the tranny. A new gasket for the front bearing retainer as well [the one the seal sits in]
Still available thru your local dealer, or I have them in stock if you can wait until your next trip out.
If you read the threads on the MAF-type tube to return fluid from the tranny to the transfer case, you should also be aware that there is no better time to change the imput seal in the transfer case then while it is out on the bench.
As far as whether or not the t-case needs work, you are welcome to bring it by for a free inspection.;)
Best
Mark A.
