Just remember, "You can piss in the crank case and it will say 'thank you' and keep running." When everything is clean it will look much better and should surprise you in a good way. You've got this.
You're just paranoid. Drive on till you can't. It probably just wants to go to Home Depot.![]()
Dex III is fine. Most of the multi-vehicle types are fine. Maxlife Synthetic ATF works fine and is a good deal. Mobil1 is my favorite but it's hard to find for less than $10 per quart, where as the Maxlife is $20 per gallon.
If you have high mile 80s, I would recommend you do drain and fills of 4 quarts with each oil change for awhile.
Is the drive flange inside the transmission housing? Isn't this the most common failure point that people talk about on the 93-94?
No, it's outside the front hub on both sides. Held on by the cone washers. Is shorter and has a shorter splined surface than later ones and so it strips out more easily.
When it engages? Or continuously?
Odd cruiser noises are either self healing or the first horseman of the apocalypse. By the time you hear it, the damage is done. I say, drive on (after greasing the spines of the drive shafts).
To me that sounds normal. My front locks instantly with a noticeable "clank".One clank when it engages. But it's not the normal driveline clunk. It's more of a ping. Then I had it do it under throttle about 10-12 pings. Then it stopped when I let off the gas. Hasn't happened again.
Not sure exactly sure what you mean by "doing it under throttle" though"
