Anyone know if it is possible to get a locker in the rear end of a schoolbus? what the heck axles do they run, anyway?
Shortbus w/ locker w/ monster winch on front and rear..... add chains for the rear tires.... you'll get where you need to go. Sure, a Mog will go further, but at that point it probably won't go that much further. No offense, Jilt, but I get the impression that driver error will be the cause of most stucks, not vehicle incapability. If that is the case, having a much more able 4wd will probably just result in much, much more serious stucks.
A PTO would really be the best winch option. After that, I suspect that a large hydraulic would fit the bill.
A 12,000lb electric wouldn't be strong enough, and to go bigger starts requiring some pretty fancy alternator/battery configurations that add cost and complexity. I'll bet that they can source a small hydraulic pump that can run off of the motor directly. Maybe just an extra, dedicated, power steering pump.
So I'm back to suggesting the bus as the 1st choice.
I like Josh's extra vehicle idea, but lets keep in mind that they've already got two bikes and avid cyclists. Perhaps just adding an extra bike per person would be a good way to get into town (or out to ruins) to look around. If biking doesn't fit the bill, maybe a small motorcycle or scooter could be carried in the back of the bus or on a rack behind the bus.
I would not want to try to tow a vehicle behind. Good for side-trips, but bad for everything else.
I'll tell ya- all this planning is giving me some serous wanderlust!
$3,000 on eBay for new bus. $3,000 for goodies: build monster roofrack w/ roll-down protection for windows on bus as well as a seating/viewing platform on top with tripod mounts at each corner, add a milemarker winch, add a dedicated pump for winch, some lights up front for driving/fog, some lights on the sides/back for reversing and camping, several 12v fans for inside the bus, a locker on the rear, if possible, chains for the rear tires, two 2m x2m sections of cyclone fencing would make the ultimate in traction aiding devices for very muddy/sandy conditions (and store easily on the roofrack-- could even be incorporated into the security for windows)
Ok, I think I blew more than 3K above.
Also inject $1,000 into complete motor overhaul-- all new hoses & belts and fix any/all leaks and do whatever PM those big old motors require, but at least a new water pump and a radiator cleanout/pressure test.
Oh, paint. But I guess that could be a work-in-progress as you go south.
Personally, I'd incorporate some simple heating devices and some good filters so that I can run some veggie oil. Yeah yeah yeah, no good at cold spots. Fair enough. There are plenty of very warm areas in Central/South America!
The beauty of the huge bus is that folks can sleep inside and/or outside as weather/safety permits... carry tons of gear... keep stuff in boxes welded to the floors for petty-theft protection... and walk around when not driving. Which is a serious luxury on such a long trip. When desired, adding the cyclists into the vehicle is trivial, quick, and easy to undo.
Ok, nuff outta me for now. Gotta Work!
+ you will be less of a target with a mexican or guatemalan tag
