Isn't the issue that the splines get gunked up and effectively seal the grease from leaving the chamber. Typically you add grease until it flows clean back past the seal. Is this not the case with the splined portion?
That's my understanding too.
If you're not seeing grease at the end of the driveshaft seal, you need to clean the driveshaft.This is basically what your driveshaft is like. It is a cylinder with a piston in it. When you fill it with grease, it becomes a hydraulic cylinder, full of incompressible grease. Go to a frame shop, look at the cylinders that are strong enough to twist your truck into a pretzel, they aren't very big cylinders. Do not fill the airspace in your driveshaft with grease, it needs to be able to compress, and if it can't it will compress something else.
It's exactly the same as any other gizmo using a similar seal.Isn't the issue that the splines get gunked up and effectively seal the grease from leaving the chamber. Typically you add grease until it flows clean back past the seal. Is this not the case with the splined portion?
The spline joint is easy to clean, the u-joints not so much so. I "borrow" make-up removal pads fromI am no mechanic, but this make sense and is exactly how mine worked. I pumped it in until it flowed clean or "cleaner".
Then I attempted to clean up the mess. I did not clean as much as I should have as now I have a faint burning oil smell from it splattering around and hitting hot undercarriage.
and keep a stash in the garage for the u-joints. The LX still tosses a bit of grease on the underside.This is basically what your driveshaft is like. It is a cylinder with a piston in it. When you fill it with grease, it becomes a hydraulic cylinder, full of incompressible grease. Go to a frame shop, look at the cylinders that are strong enough to twist your truck into a pretzel, they aren't very big cylinders. Do not fill the airspace in your driveshaft with grease, it needs to be able to compress, and if it can't it will compress something else.
I think you're dead-on. The driveshaft assembly is NOT the same has a hydraulic piston...were it, it would be locked up all the time.I like the picture as it shows how the space can 'go hydraulic' if grease can't make it back past the seal, but I'm not sure I agree with the "Do not fill airspace in your driveshaft with grease" part. Please correct me if I'm all wet on this, but if the seal isn't all gunked up filling the cavity will grease is the only way to purge the old grease from the system?
My fear with this thread is that people are unwittingly turning their driveshafts into hydraulic rams. The 'thunk' goes away because the thrust takes away the slop in the input shaft that was causing the thunk sound. I don't think we're actually getting spline-to-spline thunk, are we?
Over time pressure is relieved and the thunk returns. The user re-greases and the thunk goes away. He is left thinking that it's a lubrication issue whereas it's actually improper maintenance putting a longitudinal load on differential bits not designed for such load.
If true, perhaps we should (a) embrace the thunk as part of a 'real truck'and (b) do a better job of maintaining our drive shafts by performing a disassembly and cleaning if grease doesn't come out. I know I'm guilty of not doing the latter.
Again, just a theory I have, please correct/update if wrong.
I use either an air-powered grease gun or one with a pistol grip...standard zerk fitting on the end of a flexible hose to the gun.Hey guys, quick question: Is there a specific grease gun/fitting that is needed or will any ol' one work for the driveshaft? If so, where would I find it? Want to get stuff ordered ahead of time, including the grease etc. Maybe someone has a quick "shopping list" of what is needed to do all of the above, that would be great.
Thanks!
That should be all you need.
If you plan on driveshaft disassembly, you'll also need sockets and wrenches to remove the shafts and solvent and brushes to clean the shaft ends...
Steve
You're welcome.Thanks Steve, I'm not planning on disassembling just lubing up. Only reason I asked about the zerk fitting is because I've seen some comments on improperly sized fittings not getting the job done. I'll definitely go with a standard pump gun this time around and see what I can find on proper lubricants, thanks again.
The last two posts would benefit from an answer. I too have these issues. My mechanic says "clunk" is from inside TC but can't say why, so I want to do a double DS service first to save dropping the TC. Is there a detailed write up of how to do the DS service?
Guys, need a quick answer here as I'm trying to get this taken care of ASAP so I can head back home.
I bought a tube of moly and a tube of the NLGI-2 and spent WAY too much time pumping the moly in with nothing coming out past the seals. How many pumps of a typical Autozone grease gun should it take before grease starts going past the seals? I took apart the gun and everything seems to be flowing correctly but I was under there for a good 15-20 minutes pumping with nothing coming past the seals...something can't be right.
The zerk fitting seems to click into place nicely on the fitting, and it feels like there is some pressure in the gun, but I'm at the point where I think the gun must be faulty and I need to grab a new one. I could be an idiot and just not know how to operate a grease gun, but I think I've tried just about everything, including screaming obscenities at it
Help would be appreciated guys!
When you pump it does grease come out? If not something is wrong.
Typically, if its been a while since its had maintenance performed on it, then it may take up to 20 to 30 pumps. It doesn't take much - at least IMO - with the u-joints. Typically only 5 or 6 if its been a while. If you're still not getting any grease out, you may want to remove the drive shaft and take a look at it.
