Build The Monkey is Back
I don't have them unfortunately @cruisermatt . Once I find the sway bar that will be great to have you do that. Thanks Matt!
The parabolics on my softtop 43 are great on the front, but still harsh/jarring on the rear. I’m thinking it’s a function of the soft top being so light? I also saw some feedback that shock selection matters a bit more with the parabolics. I just threw on the Bilsteins I had…Oh well, it’s just money.
I have about 2000 miles on the set, hasn’t softened at all.
Im using the TT shocks that Georg sent with the springs and other parts. I find the balance between front and rear is very near equal. I have lost all of the old .”...hard bang into a hole and bounce back out of it” action with the TT suspension. Completely happy with it…FJ40.
I would gladly add a set to my 45. (When the economy improves) 🙄
After a hard bump or pothole the rear shoots up like a lever, fully unloads and at times, catches air! Maybe a new set of rear shocks is worth a try.
That's crazy. Mine aren't like that at all: Very pliant. It'll be a while before I drive it with the top off (still need to do the roll cage). But I'll let y'all know. Hard to imagine a few hundred pounds would do that though. Mine has the TT shocks and I think the light springs (@cruisermatt ?).
What i find most impressive is how they soak up impacts like washboard roads and potholes. It honestly takes bumps better than my Silverado.
The weight of the top and rear doors, and full size rear seat is probably the difference there
I wonder whether a 4plus rack would help by placing 100+ pounds aft of the rear cross member.....🤔 Good excuse to get one: scientific experiment.
@mdsims that is a lot of stored energy in the spring to create that lift. My FJ40 set has 2 leafs and 2 9”or 10” spacers. What also impressed me was the shock is pre-compressed for installation so it is not like….2 feet long. Then you’re lying on your back trying to press upward to align the mounting pins.
Of course I did not realize that convenience on my first shock so I had cut the securing strap and the shock slowly grew full size. We know what that looks like 😳
HOWEVER, I discovered these shock do nothing quickly. In other words they don’t absorb a compression and the eject the rod outward against the spring or tub. They compress slowly and release slowly AND i honestly interpret that action as to why my ride is so smooth and balanced. Unlike that short wheelbase see-saw it used to be
My 2 cents
Full disclose: I've yet to try the springs here, so can't speak to their full potential....
Second shot is Santa Fe this morning. Heaven in the southwest.
Last shot is a big hole which I'm confident the TTs would soak up.
