The master switch connector
Yes, it will be behind the 'kick panel'. But I'd double check (or replace your 30 amp FL fuse first). Relays DO go bad but more often it will be a poor connection (corrosion) so check that as well. A leaking windshield will allow water into that area and cause all kinds of issues. Then lastly, check the wiring bundle from the door pillar to the main switch. It is not unusual to find broken/chaffed wires there.
Hi! I have tried to replace the 30A fuse and check the wire connecting to the door lock control relay. Finally it doesn't help!
What relay should I test and replace it if it is broken? :)
I just found the aftermarket master switch unit is for the LHD. My 80 is RHD. Was this a good sign for us to know which unit is burned/ broken? Please.
All, how can I know if the door lock relay is broken?
When I replaced my master switch from SwitchDoctor (I think), it was worse than what I replaced. I ended up cleaning up the original and had better results. Maybe a bad aftermarket switch? Know any around with a working 80 you could swap and test yours in?
Does anyone know this? I found it is broken. I hope it can help to solve the problem. :)
That is the fuse for the power windows, door locks, mirrors, sunroof, and power seats.
That Sir is the fuse several of us told you to check at the very beginning of this thread. Best to just replace it and AND check the fuse block for corrosion.
