I'm halfway through a head gasket job on a LX450 for a friend of a friend. There was complaint of overheating followed by "oil in the water" and "oil consumption". I took her in and found water in the oil and steam out the exhaust. So I tore it down the hard way, so I've read (completely* unhooked the wiring harness and pulled the intake mani & head at the same time). I had the machine shop pressure test, vacuum test, and check the head for flatness, and it passed all tests. So I've got the parts kit and i'm about to go out there and do some cleanup before reassembly. I have a problem though, and it has to do with the asterisk above. When pulling the head/mani I had not disconnected a one wire sensor screwed into the top/rear/left of the block, and damaged the electrical connector of this sensor. I assume it to be a coolant temp sensor or switch, as the probe would normally be immersed in coolant. However, a stop at my local Toyota and Lexus dealerships, as well as some Autozones and NAPAs and the like have yielded bad results. For one thing, the diagram that the dealerships have to look at for reference appears to have been drawn by a 3 year old. The Toyota guy may have found it, but told me it had been discontinued. The Lexus guy may have found it but I'd have to pay 90$ to get it ordered and in my hands to compare it to what I was trying to replace. Neither appeared confident that they had actually found the right part, or even knew what I was talking about. Both were looking at the same diagram. There is no visible part number on the sensor. The Autozones don't have anything with one wire that has either the correct electrical connector or thread pitch...What is this sensor called? Is it commonly used in other Toyotas? I'm thinking junkyard, here..Any suggestions? You guys know of any component locators available online or on this forum? Many thanks to any and all in advance!
Back to the garage! By George, she'll live again!!!
