The infamous brake issue....
93jspec
Cruising Central Texas
Canyon Lake, Texas
Website
www.facebook.com
Lets get the formalities out of the way, yes I used the search option, and yes I checked the FAQ. After reading through the articles and checking things based on those readings I still have issues.
1996 FZJ80 140,000 miles
Slee 4 inch lift on 35s with the slee braided brake lines.
A little over a year ago my club did a super fun run up here in Alaska. During that run my brakes went super soft. I would apply the brakes and the pedal would almost hit the floor before the rig would stop. I could pump the pedal and it would stiffen up but no change in braking. I figured maybe I had a line swell or get a cut so once we got to level ground I busted out my 10mm wrench and trail kit with brake fluid. I checked the master and no fluid loss. Then checked each corner and line and no leaks. We bled the system starting from the furthest caliper, then LSPV and then front corners and the brakes worked for about 30 min or an hour on the trail and them the same softness. At this point I figured maybe I had moisture in the lines, or maybe one was swelling up when the pedal was applied because of the loss of fluid. A few days after the run I completely swapped out the fluid, complete flush with a pressure bleeder doing the same process listed in the FSM. The brakes worked flawlessly that day so I parked it. The next morning I figured I would drive it to work and wash it off but the brakes were back to being super soft. At this point I bought a reman factory master cylinder and replaced it and then bleed the brakes according to the FSM. The brakes worked great for a day and then went to s*** again. At this point I put it on a friends lift and pulled all four tires. I ended up replacing the drivers front caliper (OEM) and the front brake pads (OEM) on both sides. I also replaced the only non-braided line with an OEM soft line. Bled the system according to the FSM with a pressure bleeder and yet the issue persists to this day almost a year later. I have missed out on a ton of multiple day camping trips because of this. I really don't feel like doing the trouble shooting by parts replacement method...replacing the LSPV (according to mud search not something that fails very often if ever) every braided brake line, the brake booster and three more calipers....or taking it to the dealer
Any useful thoughts or possible solutions would be appreciated.
Thank you!
From what I've read here on mud and my personal experience it's not that uncommon to get a bad master cylinder (reman or new from the parts house) right out of the box. I had to put three on my 95 F350 before the last one worked. I've never really bought oem parts before because my 97 Cruiser is the newest vehicle I've owned. Sounds like your master cylinder is bad to me. On a side note what brake fluid have you been using? Some fluids do not mix well and cause the lines and seals to swell and leak.
Amazon.com
SSBC A1704 Brake Pressure Gauge Kit
by SSBC
Price: $49.95
Start at the TMC then do calipers.
Could it be possible you have a soft line that is collapsing?
This allows each component to be tested independently instead of guessing.
I will look and see if I can find an OEM master or maybe take my chances with another reman from a local auto parts store. As for fluid I will have to check when I get home, but I have been using the same brand for years so I know I am not mixing brands, plus by now I have probably flushed the entire system 3-4 times easily. Thanks for the input!
The only other thing i can think of besides what has been stated is to force the abs to cycle in case there is air in the abs unit itself
I just Googled brake fluids and apparently you can mix them all except DOT 5
Amazon.com
by SSBC
Price: $49.95
That's kind of what one of my thoughts was ( I was thinking swelling like a balloon )so I replaced the only soft non braided line left in the system.
Now this is a new one on me. I will look into this and how the ABS links/controls the system.
Forget the fluid thoughts, you can use water in the braking system in an emergency but, drive gentle as the boiling point is obviously an issue, DOT 5 no good, 3 and 4 mix.
Given you have no leaks I too would be looking at the master cylinder or ABS system
The Land Rover is better in this area, you simply plug a laptop in and bleed the ABS module while sitting in the drivers seat, for 80 owners it is find some gravel and activate the ABS a couple of times and then re-bleed. Normally a bleed with a pressure bleeder is all that is needed but, I too had a problem last December when I replaced the entire system, everything from the hand brake cable to the callipers. ABS activation improved the 'feel' but confess it does not seem as good prior to the overhaul.
regards
Dave
It's really odd that your brakes seem to work for a short period of time after bleeding and then get mushy. It kind of sounds like your brake fluid is getting overheated. Is it possible you have a dragging rear caliper (since you replaced the fronts) that heats up the fluid and kills it in a short period of time? Or potentially the parking brake mechanism is not releasing causing the rears to always be slightly applied?
I will pull the rear and check again. As for the E-Brake...it has not worked in awhile >.< When I replaced a rear axle seal awhile ago I really should have adjusted it.
I had a rear caliper hang up (just barely) and i could both hear a howl from the rear and smell the hot pad odor even though there was no indication via drag on the truck. I gotta think you'd know it if you had a hanging caliper. It's really easy to actuate the abs, just need a gravel road, then try bleeding again.
I tried to activate the ABS yesterday but the pedal is so soft right now it slows down like a fat kid rolling down a hill. So that being said I will have to borrow the pressure bleeder from my buddy again and bleed the system hoping I get a stiffer pedal thus allowing me to smash the pedal and activate the ABS.
Definitely need to activate the ABS more than a few times. That really helped mine. I use a pressure bleeder to flush the system, but even so....the LSPV can be very hard to get air out of.
Had to go from passenger rear to LSPV and back quite a few times to get all the air out my system. Once you get enough 'pedal' to lock up the brakes....hit a gravel road or a grassy field and really give the ABS a work out.
This weekend I managed to activate the ABS several times and the brakes were perfect the rest of the time driving. The next day I went out and back to the soft pedal. I am ordering a reverse brake bleeder system and will bleed, activate ABS, and bleed again and see what happens. IF it continues I will replace the new reman master with another one and repeat the process. Push comes to shove I may take Serinitys advice and remove the LSPV.
Sounds like air in the abs. Did you bleed the brakes right after activating the abs? I also cycled the lspv rod by hand when bleeding
It's really weird that it can be fine and then all of a sudden you get a soft pedal after it sits overnight.
No, I did not have access to a pressure bleeder this weekend so it was more of a "will this work in my case" test and it appears so. Once I get a reverse bleeder in I will bleed, activate ABS and Bleed again..if that does not work then other more drastic measures may be taken. After reading the linked thread I am seriously considering dumbing down the system with the removal of the ABS and LSPV, but at a minimum the LSPV. I like having the ABS for the 6 months of snow covered roads.
