The Goat Tail - 1970 shorty trailer build
wngrog
Supporting Vendor
Moderator
Canton, Mississippi
I picked up a 1970 parts truck back in January to rob some parts off of to make my 1967 FJ45 a little prettier.
I robbed the fenders and the hood that matched my FJ45 perfectly.
I grabbed the perfect horn button off for my FJ40 steering wheel.
I pulled some other missing items I needed and let some others grab some parts they needed.
I’ve had some people want some parts so I’ve been steadily pulling pieces off to the point that the main value left was the perfect little 1/2 doors on the tub and I really wanted to find a reason to keep them
Last week I saw this little shorty trailer on the TLCA Facebook and decided this was the perfect compliment to my FJ45, the Goat
Having a tractor makes pulling a drivetrain a snap.
The dude with the shorty was kind enough to share some pics from his build so I think it will be cool
So after getting the engine out it was full on get it
I used 4 Milwaukee Torch blades and 5 4.5” cutoff wheels but I got it.
I had to back The Goat up to the Goat Tail and pretend a bit .....
I’m missing a few parts.
Lower spare tire hinge.
Reflector rings.
Tail lights.
One bumperette.
I had a couple hours after work to polish The turd a bit.
I scraped all the barnicles off and hosed it down top and bottom with a couple cans of rust Converter.
After that set up I rubbed the exposed rust with boiled linseed oil
Well that's the perfect plug.
So what’s with the boiled linseed oil?
I discovered the hot rod “Patina” guys are using it to protect the exposed rust
I have been using it in conjunction with CLR to clean he paint and preserve the exposed rust.
Check out what the combo did for my 1967
Lights are in.
I also added some HiLift cargo rails I had to the tub. Cut down the whip.
Also my local @metalshaper is making a face plate out of a floor pan. We are going back and forth now on that.
Now I feel bad you passed along those old acorns.
@beno sent me some OEM shocks for it. I know that sounds silly but the price is right on them and I know they will fit.
@Cruiser Corps sent me a missing spare tire hinge. I’ve got to splash some paint on it
I put some new reflectors on
And I picked up the steel to complete the trailer
My welding friend got sidetracked with a garage remodel so the Goat Tail has been on the side burner.
Today I figured out how to move it by myself so I got it in the shop to do final prep before we weld in the tongue in a week or so.
The Goat donated the 700-15’s. I needed a good spare for the truck so one went under and 3 went on the trailer
I swapped out the hinges after this pic. Hid the pink one on top
I got the underside and the bed all clean and treated with Fluid Film
Installed the OEM shocks
Plugged all the screw holes and hooked up the lights together to be wired to the front once I figure out how long the tongue will be
The tube is what I found to move it. It is VERY tail heavy now. Takes a lot of leverage to tilt it up.
