The forever one time build.
A gift. Yeah, free is my favorite price. Some friends decided I would put new life into a stalled idea. This '71 was a one owner, then dad passed away, it was passed down to his daughter and her husband. They sent it off to have it refurbished through some local channels, that ended up being one bad luck story after another. Drive train was pulled, disassembled, and tossed in a box - for no reason, resulting in parts being lost. A tree hit it, causing top damage, and if you look close, you'll see there is a ratty replacement top just sitting on top of the other fiberglass roof that is missing 1/3 of it.
With no motor, no trans, no seats, I'm really left with a blank canvas to work from. Every bumper and bumperette have towing damage, so those are coming off as well. There is some rust, but not horrible, and well within my capabilities to handle.
The plans right now, will be a frame off -but not a restoration. Once the engine mounts, suspension mounts, etc are all settled on, then the frame is off to get blasted, and powdercoated.
The tub will get rust fixes, and end up covered in Mustard.
Dash will stay pretty stock and simple.
Full cage, that still has family room.
Power steering for sure, but this is where the indecision comes in. Steering depends on axles, depends on tires, depends on suspension, depends on axles, tires, susp. I'm caught in a loop, but that's really alright at the moment. I'm about to head off on 3 to 6 months of work, and I won't be able to touch it until after that, so I have time to think things through.
What I really want, is Dana 60's or 14 bolt, front and rear, Coil overs, 4-link front and rear, running 39's or so. Probably 17" or bigger rims, so I can accomodate great brakes. Arguments for and against, I'm open in input. This will be a daily driver, with some play time, but not much. I don't want to harm value, but I don't plan to sell. Something that is fun, very useful, very strong, but still driveable in town. Maybe some highway driving, but really rare, and probably more likely to get towed if over an hour away.
In the first picture, I'm installing a Toyota 1UZ 4.0l v8. It's attached to a w56, with mini truck transfer case (These parts were available, and ready to go, so I just put them in there... I like the all Toyota, and v8, and manual. I think really, a chevy 5.3, 4l60e, and Atlas II is the way this is going to end up).
The output is to low, the center frame cross member in in the way, so that will need adjusted. The driver exhaust manifold hits the steering box, so that needs replaced/moved, and the oil pan is too close to the front diff housing, so the diff needs moved. I'm really at a spot where 3 things need to happen at once before moving forward. Mix that in with figuring out where the suspension mounts go, and I'll have good progress.
I'm going to run a 110" wheel base, or there abouts. This will clear the oil pan easily, along with giving the performance and look that I'm after.
I've got 3 to 6 months to think about all that. Once I come back, there should be a flurry of progress, and new parts, and junkyard parts. I'll be doing most everything myself. All the fab and design, engine and trans, wiring, etc. About the only thing that will get farmed out, is the sandblast and powder coating.
Looks like that kid has the right idea - - why not just make a back lot funhouse?:confused:
That's a sharp looking rig Millardo. If I can make mine come out that good, I'll be very happy.
To say "I don't want to harm value" with a list of mods like that will become very subjective. At the end of the day, what type of vehicle will you have ended up with?
Suppose a little more detail on the harming of value is necessary. Let's just say I would like a good working, well thought out platform. If I start running down the wrong track, somebody please give me a verbal slap.
Interesting, I'd say a power steering should be major SURE :)
Subscribed , all the best
cheers!
I promised a "forever" build. So, here is my first check in, in awhile. I travel, for extended periods, for work.
I want to tackle the best drive train design, so I can buy once. The W56 is gone.
What I have in the garage.
-1UZ 4.0 V8
-71 3-speed and transfer case
-R154 Supra 5speed
What I want to do.
-Decent power, 300+hp.
-Fun. While I don't plan on abusing, I will drive hard on occasion.
-Driving will probably be 60% intown, 35% Highway, and just 5% offroad.
-I would prefer to avoid the Chevy v8 route.
So, if you had your way, what combo would you suggest. I want to avoid having to move the rear axle. Not saying I won't, but I would rather keep that as an option, instead of something mandatory.
Junkyard designs, and brand new crate assemblies will be considered. I6, V8, diesel, manuals, automatics, card, fuel injection. What would you build if you were in my shoes?
Have you checked out Jetranger's build thread? I'd love to have a UZ in mine!
