Finally found a small rooftop air conditioner for the camper. 9200btu, <2000w max with cooling and heat built in. This is the golden ticket. Locked rotor amps = 58.4, so i need to read up on when that's seen. #Edit: locked rotor amps is the compressor start-up amperage. That's pretty high. Need to look into soft-start capacitors.
Coleman Mach - Mach 8 Cub Low Profile Rooftop RV AC | Airxcel
The Coleman-Mach Mach 8 air conditioner was built to provide high energy output with one of the lowest profiles on the market. Learn more about the Mach 8 here.www.airxcel.com
Was just reading about those, watched a vid too. Only downside is expense at $300, but it gets the job done.
So at this point, this is just a custom camper build, right? Because there cant be anything left of the original other than the general shape from what I can tell.
And, p.s. dont stop, I love this thread, and this build
correct. Custom camper build is accurate.
...and HUGE!! Ford don’t care!
