Took on a project this weekend to replace my rotted out stock muffler and gain some ground clearance in the process.
With my 1.5 inch body lift, I was able to run 2.5 inch pipe from the converter to the tail pipe which now exits just aft of the passenger rear tire. I did have to crush the pipe down to 2.25 inches where it passes between the body and cross member, but it's far better than the stock pipe which was under 1 inch thick at that same point.
To get proper routing and orientation, I also cut the collector (post converters) where it passes over the frame rail and welded it back together where I needed it to go. I also did some trimming of the sheet metal in passenger rear wheel well to gain some clearance.
I used a 20 inch Dynomax muffler and it is very close to stock sounding. I'm not a fan of noisy mufflers and this one seems to work well.
