The Buzzz build
Well got tired of stumbling over the 5 speed in my garage so this happened....
Should have the tail shafts back in a few days, no real idea on getting the handbrake sorted as of yet...am maybe thinking of making a bracket to join the HZJ75 cable to the 55 one. Also have 2 spots on the tranny tunnel where the box hits so have some sheet metal work to do.
Hopefully make some progress this coming weekend....
Also bought this and a 12ht manifold :D
Realistically turbo is a fair while away, really just want to get the gearbox and wheels done and enjoy it on (or off) the road before I pull crap apart again.
Well it's been a while, moved house so have had minimal time and also no undercover area to work on the bus....
Although somewhere in between the searing heat I did make some progress on the front suspension as the front end had a sag which was bugging me...and I wanted more lift :)
After trolling through Archie's thread on 75 series spring swaps (has some awesome info) and given that I'd used the 75 springs on the rear I decided to give it a go. I ended up using EFS heavy duty fronts (because my bulbar weighs half a ton) with a 2.5inch lift.
Photo of the 75 series front next to my old 55 spring
Before (even the pooch was struggling with the heat)
After
Shackle angle before
Shackle angle after
Am pretty happy with how it turned out, the only thing that I'm going to change is the front shackle hanger. Pretty sure its bought up in Archies thread but the 75 springs and bushes are wider than the 55's. To overcome this in the meantime I had to pack it with washers either side....
I'm planning on using 32NB pipe that has a 4mm wall thickness (giving it a 34.4I.D) which I'm going to weld in place of the factory bushing tube so that I can run 35mm bushings.
Photo of shackle issue...
I also started playing around with the turbo setup however after getting halfway through making my 3inch dump pipe I realized I'd welded the pipe onto the flange upside down!!!! Haha I actually just started pissing myself laughing once I worked it out. Needless to say though its been sitting ever since.
H55F?!? Please show us how the shifter hole through the tranny tunnel will work. Also what you do for a cross member...
For you Pablo....
Used the same crossmember I made for the 4 speed however I modified it slightly to lower the gearbox by 15mm or so
And shifter. Hard to see properly because of the light but I grafted a 60 series top cover onto the 55 tunnel. Also had this tunnel setup with my 4 speed (which was originally out of a FJ60) so the H55 went in pretty easily.
