The ABS mod?
Do you think tire size is a factor?
Did you run stock size with studs or smaller?
I will be buying two sets of tires this year, my new 35" mickey Ts for the fun stuff and winter tires for survival, it will be hard for me not to stud them.......convince me.
On every vehicle except my FJ40 i ran a winter set of tires, My take was I will buy 2 sets of tires in 8 yrs no matter, and a spare set of rims gives you more flexabilty, and is cheaper in the long run.
I understand the compound used to make new winter tires combined with max siping creating smaller tread blocks with lots of corners is a good thing and very effective........no argument from me.
The tires i just put on my work truck look just like that........only they also have studs ......why not? I figured the manufacturer but those little holes in the tire for a reason.......And I do have to admitt I drive in the most extreme conditions over mountain passes covered with ice that can see snow any day of the year........... I guess I am old school.
Geordie R.
Geordie
If you stud Blizzacks you waste the best part of them, and you will be disappointed with the sidewall flex in them. If you go with studs, put them on a dedicated snow, not ice tire.
There is no question in my mind that Blizzacks without studs will outperform more winter driving conditions than studs. They are quiet, do wet, snow up to high center, slush, water, ice and even dry all without the high treadwear associated with Blizzacks.
I'm still not a fan of the sidewall flex, but I recently purchased and extra set of rims, and will have the ability to get sumthin else for this summer (most likely just the stock LTX for towing).
Give it a shot, I don't think you will be disappointed in jumping onto the tire tech wagon.
HTH
ST
Without the VC, the ABS can still be run. The ABS cannot be run effectively with center diff locked.
The reverse translation would hold...
[special scenario warning]
You should not drive a vehicle in ABS mode with the VC failed into always locked mode. There are two reports of VC failed into lock that I'm aware of. In this case, you might be better off to engage the CDL which should turn the ABS off as it may fight against the failed VC.
[/special scenario warning off]
