OK, I know about the CDL switch mod and the 7-pin mod.
1. The CDL switch lets you engage CDL in 4H
2. The 7-pin mod lets you disengage CDL in 4L
But is there a mod that lets you take control of the ABS? Like turning it on and off independently of the CDL?
I've driven with the viscous coupler seized completely by the PO and there was enough flex/play in the transmission components to not engage ABS. So my conclusion is that ABS can be used with CDL. Of course I'm not planning to use ABS off road while going at 5mph, I would like to use it on slippery roads.
Imagine such a situation (now popular as it's winter here):
The road is covered with a few inches of snow. Without CDL you have to be very careful on turns as any pressure on the pedal will make the rear spin (and turn the truck around). So to drive on such roads you turn the CDL on. You simply point the truck and press the gas. But you loose ABS. I don't see myself looking for the CDL switch while being in a panic braking situation and wait until it unlocks and turns the ABS on.
So is there a mod to have an ABS on/off switch???
Keep the shiny side up.
