I just noticed something from the photo you included in post #115. See the position of the red knob on the temperature potentiometer? Compare that to my photo in post #5. Yours is set as low as it can go, which should make the A/C run so much that the evaporator coils freeze over. My guess is that the PO added the black wire because the A/C was not working well and he/she thought the problem had something to do with the board. What's far more likely is that the system is either low on Freon or the expansion valve that sits between the condenser and the evaporator is plugged up. Or maybe there's moisture in the refrigeration circuit. Either way a good A/C shop should be able to diagnose what's wrong. Also, after you remove that extraneous wire you should set the red knob back to something reasonable, say 34° or 35° according to my photo in post #5. You want it set to where the A/C stays on until the evaporator get within 2-4° of freezing, then shuts off the compressor. The adjustable temperature potentiometer is part of the circuit because the thermistor that senses air temperature is not a precise device and the potentiometer allowed the factory to calibrate each sensor. (I have no idea if Toyota actually did such a calibration on every vehicle leaving the factory; I sort of doubt it.) It's interesting to note that in 21st century vehicles like my 2014 FJ Cruiser, the whole A/C system is basically the same as your FJ60. There's still an A/C Amplifier and an evaporator temperature sensor, but of course all the electronics have been updated to modern devices.@TrickyT thanks for all the info!
Thanks again for all the help. I had noticed my red knob was set wrong based on how you had yours marked. It’s really helpful that you put so much work into it. I rarely have to ask questions on here bc most of it has already been addressed.I just noticed something from the photo you included in post #115. See the position of the red knob on the temperature potentiometer? Compare that to my photo in post #5. Yours is set as low as it can go, which should make the A/C run so much that the evaporator coils freeze over. My guess is that the PO added the black wire because the A/C was not working well and he/she thought the problem had something to do with the board. What's far more likely is that the system is either low on Freon or the expansion valve that sits between the condenser and the evaporator is plugged up. Or maybe there's moisture in the refrigeration circuit. Either way a good A/C shop should be able to diagnose what's wrong. Also, after you remove that extraneous wire you should set the red knob back to something reasonable, say 34° or 35° according to my photo in post #5. You want it set to where the A/C stays on until the evaporator get within 2-4° of freezing, then shuts off the compressor. The adjustable temperature potentiometer is part of the circuit because the thermistor that senses air temperature is not a precise device and the potentiometer allowed the factory to calibrate each sensor. (I have no idea if Toyota actually did such a calibration on every vehicle leaving the factory; I sort of doubt it.) It's interesting to note that in 21st century vehicles like my 2014 FJ Cruiser, the whole A/C system is basically the same as your FJ60. There's still an A/C Amplifier and an evaporator temperature sensor, but of course all the electronics have been updated to modern devices.
Thanks for the response! I’ve tried to do everything correctly bc I really don’t know much about it. There is a sticker on the radiator support that says 0.6 - 0.8 kg R12. From what I have read you should reduce that to 90% which is 0.72 kg so that’s why I’m using that amount. And the machine I am using can be set to kg so that seemed like the easiest way to not make a mistake. But it may be under filled. I could try putting 0.8 and see if it changes.Wow. What a heroic effort! The low pressure switch should open if the output side of the compressor drops below ~30psi. So if yours is dropping to 10, that's why the compressor clutch disengages. So I think your pressure switch is working the way it should. So why can't the compressor make more pressure? You sure you don't have a leak somewhere in the system?
I don't have the FSM for the FJ60, but for the FJ62 it says it takes 800-900g (1.8-2.0lb) of refrigerant. So you may be underfilling the system. Since you've replaced pretty much every component that's about all I can think of.
Thanks for the info!Did you pressure / vacuum tested the system? Does it hold pressure / vacuum?
When it runs what are your manifold pressures (high&low) before and after it shuts off?
Low vacuum would say your TXV is not opening and starving the compressor of refrigerant. High pressure indicates possible contaminants in system creating high head pressure on compressor.
Is the electrical AC circuit solid? Check for loose wiring and relays..
also check for air flow at the evaporator and condenser....
With the vehicle off by pass the circuit and feed the clutch 12vdc.. see if it engages and stays engaged without issue...
The txv is what controls his much refrigerant goes to the evaporator and is also the point where refrigerant goes from high pressure to low pressure and from liquid to gas refrigerant... what opens and closes the txv is the bulb that is attached to it via a thin tube..
Ideally you wan to power the clutch without the engine running to see if it stays engaged, futhermore with the engine not running you will be able to hear if the clutch stays engaged and or if disengages with constant 12vdc.Any other suggestions?
Yes, the line from the condenser goes to the IN side of the dryer (aka "Receiver" in the diagram). Here's general description of the A/C system:@TrickyT @MANUCHAO thank you both for the help. I’ve now got some new things to try.
Could one of you confirm that the line from the condensor goes to the IN side of the drier?
Also, I’ve been reducing the r12 amount by 10% but I found one thread where someone had went through a lot of this and found that it ran better on r134 without being reduced. A few people on here have said this could be a symptom of low refrigerant so I’m going to try that first and see if maybe it was just that all along. At least that seems like an easy thing to try.
Man thanks again, I think you’re right that there could be more than one problem. A lot of things have pointed to not enough refrigerant. So I’m definitely going to add a little more and then connect 12V directly and see what happens. Hopefully I can do this tomorrow.Also, In one of your earlier posts you said "the pressure would go to about 30psi and then drop to 10psi" which I assumed, now I think mistakenly, was being measured on the output side of the compressor. But then in a later post you said "Low side was going from 10-30 and l believe high side was around 100." So my previous comment in post #125 about the compressor not making enough pressure should perhaps be disregarded. In my FJ62 FSM it says that in a normally functioning system the low side of the compressor should read 21-28psi and the high side should read 206-213psi. (Conditions: air temperature 86-95°F, engine @ 2000rpm, blower fan set to high speed, temperature control set to cool.) So the 100psi you are measuring is too low, which may be attributable to not enough freon.
You can temporarily bypass *all* of the A/C control logic by disconnecting the connector on compressor clutch and running a wire directly from the clutch to +12v on the battery. The clutch should then engage continuously and allow you to measure input and output pressures of the compressor and compare the results to the numbers above.
Lastly, you may be dealing with more than one problem, which make diagnosis more difficult. I now think you should bypass the A/C control logic altogether, as I describe in the previous paragraph, and just make sure the refrigerant circuit is working correctly. Once you confirm that the mechanical/freon half of the system is working you can move on to the control logic. In other words, divide and conquer.
That makes a lot of sense. You're right, the pressure switch does attach to the small high pressure line. It is a brand new expansion valve but it could be clogged. Of course it's the hardest thing to replace. It isn't denso, so I will order a denso one and make sure it's the best chance to be good before I tear that out again. Thanks again!Someone please correct me if I'm wrong, but I believe the "low pressure" switch connects to the high pressure side of the system. It's there so that if there's too little freon in the system or the compressor isn't working correctly, it stops the clutch from engaging and potentially destroying the compressor. So it's just a safety switch. It's the A/C amplifier and the thermistor that controls the normal cycling of the compressor. You don't want moisture freezing on the evaporator coils and blocking air flow, so the A/C monitors the coil temperature and cycles the compressor off a few degrees above freezing. Then, because the fan is blowing air over the evaporator, it warms up and the compressor comes back on. A one minute cycle time seems OK to me, but it depends on the ambient air temperature and how well the overall system is working. But you do want to make sure the red potentiometer on the A/C amplifier is set to cycle off the compressor before the evaporator coils start to freeze.
However, 320psi is much higher than the 206-213psi specified in the FSM. And I wouldn't expect the low side to drop all the way to 0psi. The FSM says if the low side pressure drops to 0 that the expansion valve may be clogged.
The expansion valve includes a "bulb" that controls the opening of the valve. I don't know how to test if the bulb and valve are working correctly as a unit and the FJ62 FSM is silent on this issue except to acknowledge the bulb's presence. But if the expansion valve was "closed too far" (whatever that means) then the pressure on the low side of the system could go to zero. I think that how this part of the A/C system works would be basic knowledge for any competent A/C technician. When I started this thread it was all about the A/C amplifier circuitry, so I think I can't really help your specific issue much more than I already have. But do let us all know how problem get resolved.That makes a lot of sense. You're right, the pressure switch does attach to the small high pressure line. It is a brand new expansion valve but it could be clogged. Of course it's the hardest thing to replace. It isn't denso, so I will order a denso one and make sure it's the best chance to be good before I tear that out again. Thanks again!
For the EE’s out there, here are the schematics that I reverse engineered for the two boards.
Both boards use a proprietary IC for the controller. On the FJ62 it’s a Toshiba T2333 and on the FJ60 it’s a Nippon Denso SE012. I could not find data sheets for either.
Does anyone know if that Ignition Start Inhibit ("A" in the first diagram) is actually used on U.S. market FJ62s? On the evaporator on my 62, the black wire is physically present on the evap case harness, but is just plugged into itself - leaving the connector on the AC amp open. On another 62, the black wire was plugged in to the AC amp, but the other end didn't seem to go to anything.For the EE’s out there, here are the schematics that I reverse engineered for the two boards.
