I think a slightly sub-optimal tune will have less impact on torque curve and power levels than a mismatched turbo.
If you guys are close with your tune, you should see a decent increase in power, even with stock pump and stock aneroid pin.
No amount of tuning will change the physical limitations of the turbo.
Stock pump is capable of supporting a pretty substantial increase in power.
If the turbo characteristics are close, and your tune is close, you should be amped, not under-whelmed.
With stock turbo, and stock pump, I had my 1HD-T running at 15psi, then upped it to 18psi and upped the fuel (had it boosting to 22psi for a while).
The difference between 15psi and 18psi would have been about 1/2 turn on the main fuel screw, and a long way of maxing it out.
The difference in performance was significant, definitely very noticeable.
I ground my aneroid pin to stop it cutting fuel when boosting above 15psi, apart from that, the pump was stock, and I was simply trying to maximise fuel setting and boost while staying within "safe" EGTs.
This was 10yrs ago (Graeme was still tinkering with stock ct26, and hadn't looked at IPs) with a stock turbo, therefore larger turbine than what is currently being used, so less responsive, and with smaller compressor than current upgrades, so less air volume, and well outside it's efficient range by a long way, so excessively heating the intake air.
Far from optimal turbo parameters, but it still ran like a scalded cat.
My supra setup is maxing out at 15 with the fuel screw wound flat bikkie on my 1hz.(unsafe) It makes more than enough power realistically for a 400k km old motor. I could spend way more time and money tuning it, however it is now going to live on a farm and be nothing more than a paddock basher for my stepdaughter until I reclaim it and rebuild it for a third time.
The supra turbo is definitely a cheap and viable solution for 1hz owners on a budget. It gives you enough punch to enjoy the 1hz on the highway while using easy to obtain factory components. (Just don't bend the compressor fins like I did while clocking the comp housing!
Keeping it in the family.
