Compromises for everything. Boils down to goals, money and complexity
And patience,
and a willingness to fxxx things up and try again
Yeah, compounds is the dream. Probably a pipe dream for me though. Too much of it is over my head!![]()
Haha you don't give up. Don't worry, you're not alone! I'll get one maybe next week, will stick it on youtube so everyone can see. And yeah, melting pistons is the biggest issue. But the improved turbine means you can run a bigger set of wheels and still get the same response as before, but better overall performance. Results on petrols are promising to say the least, 1000+ rpm drop to hit peak boost was one I sawThose have titanium wheels, nice. Too bad the 1HDT has a cast block, or we'd be able to get away with way higher EGTs by using a Ti turbo wheel.
Any luck with the video?
Not in this application, but in aluminum block diesels with better piston cooling, running a Ti wheel removes the turbo as the EGT limiting factor given its high melting point.Titanium wheel has nothing to do with egts.
You're very observant. I simply said "it's too bad the 1HDT has a cast block". If you would prefer, I can run all my comments by you first in the future, so that you can judge their appropriateness for this form and thread.I thought you were talking about this application. This thread is about this application mind you.
Had a chat to old mate today re: BW EFR. He thinks it may be feasible to obtain a supercore and do some magic to make it work in a CT26 housing. This could be a bit of a game changer, he reckons they are miles ahead of the competition both response and performance wise thanks to the turbine technology and good compressor design. Also says the cores are really well designed and will hold up to a lot of load. Will keep you posted![]()
I dabble in TDIs, and it's nice not having to worry about the block/pistons before the turbo. At least not until ~1,650 F
I really like BW turbos but that new turbine issue has turned me off bigtime. Too bad. I still think their a good company but Ill need a few more years to see where the dust settles. Doesn't help either when guys post that they drop the ball on warranty too. As if the catastrophic fail isn't bad enough you also get to eat the over priced turbo. Leaves me with the feeling that their margin of safety is right on the edge.
