Just for further clarification, . . . .
the turbo we're talking about is the CT20b
Also known as a "small ct26", for further confusion.
Just for further clarification, the CT20 is the tiny turbo from a 2.4l 4runner/surf (2L-T/E). The turbo we're talking about is the CT20b from an MR2. Different beasts.
Dougal. I've read about your larger turbo swap and resultant economy drop before and found it quite intriguing. I don't suppose you measured drive pressure with both? What do you attribute the economy drop too? Simply being somewhere towards the edges of the map?
Nice! What turbo are you running on that?
Yes the CT20B is also used on some MR2's and I think on the twin turbo Supra. It is a lot bigger than the CT20 from a 2LT.
I think the economy drop was due to compressor efficiency loss. The bigger compressor was in a bad place on the map (it didn't have enough surge resistance) at cruise and at lower rpm. I wasn't able to measure drive pressure because I misplaced my gauge and brackets. I've found them all since. But I guarantee drive pressure would be higher.
The larger turbo though was a hoot to drive when over 2000rpm. 4th gear passing was addictive and in 5th once the rpm was up it kept pulling. It wasn't ludicrous power, it felt good the way it spooled but was just ~500rpm later than I like. Current plans are afoot to do much better. But life keeps getting in the way.
As far as lego goes, with the TD05, you still require a Toyota CHRA compatible Turbine housing though no? Or are you suggesting an completely different core all together.The problem is, if its not exactly what you like its very difficult if not mpossible to change out turbine housings for just slightly smaller or larger to fine tune it. With a td05 its literally like lego and all the info is out there, you can choose multiple suppliers for almost every component. Makes tuning infinitely easier. . I personally feel you guys will shell out a big chunk of change for a toyota turbo and get stuck with it. Better get it right the first time. Very tuff to get it right the first time by the way.
So in a nutshell, TD05H aside...
Correct me if I am wrong, Im trying to generalize all the info here....
?- A Stock CT20B with a 17020 Turbine housing alone (essentially a 1HDFTE turbo) is a large upgrade. Smaller turbine wheel and larger compressor wheel.
Does anyone make these complete for sale?That gives you a compressor similar flow to the supra wheel with a much faster spooling turbine. So yes it's the best bolt on solution.
However. Aftermarket turbos vary hugely in quality. The difference between a good turbine wheel and a crap turbine wheel is about 20% in turbine efficiency, big difference in spool, boost, drive pressure and top end power.
Sent from my SM-G900I
Sorry i cant find anything complete and im not exactly a turbo wiz
Sorry mate. One more question, will i need an adapter for it or will it bolt to the 12ht exhaust manifold? Again cheers for being patient
Type this into your favourite internet search:
ct20b 1hdfte
Yep my BBX with FTE core in housing to suit 1HDT was only a couple hundred more...Only "known" seller that came up is asking ~$2300aud for an oem turbo which puts you in the realm of gturbo pricing.
Or back to unknown ebay type stuff
