I have seen few posts lately with ignition trouble both here and on ccot discussion board, so I am posting this very common test for the ignition coil.
Regardless of what ignition system you have or what coil you have you can use this test .
You can use your truck battery to do this test or any good 9V batt.
Use a good spark plug and and make a good connection to the coil high tension wire, Then use a length of wire to ground the spark plug.
Make sure you take any wires connected to + and - terminals of the coil out before you do the conections for this test.
In the diagram you get the basic idea of how to make the connections. This test can save you a lot of time when you have staring problems that you think is not fuel related. If you don't get a spark from the spark plug recheck your connections and try again ,no spark , you need another coil. Remember it is a touch and go to the - coil terminal and not a solid connection that will make it fire the plug.
This post is likely useless to most of you people.
