Testing locker operation on high traction surface.
Portland, OR
I'm looking around to purchase a LC/Pink Panty and I'm curious what the process is for testing locker operation if there is no low traction surface available.
Although I understand you shouldn't lock it up on a high traction surface as a rule - would it be OK to operate the lockers as long as you don't move the truck thus avoiding any driveline binding ?
Or forward in a straight line only for a few feet - which in theory again should not cause much stress as all the wheels move the same distance at the same rate...
Apologize for such a newb question (Hey I'm a newb) but I'd hate to grenade someone's diff on a test drive...
And I did search. :flipoff2:
The safest way is to jack it up. That said, I test mine before each trail run on asphalt, but wouldn't recommend it on a test drive on a rig with unknown axle condition. It's tricky to get it to lock and unlock on high traction surfaces, especially if your not familiar with their operation.
Add to that- they may not engage at all if they haven't been used in a long time. This doesn't mean they won't work, but just that they need to be 'exercised'.
simple turning the steering wheel from left to right engages the front one ime (standing still) driving backwards and forwards in a straight line wont do them any harm to try and engage em, although the rear locker can be stuburn..
yup, in principle going straight should cause no harm even on asphalt. Assuming they lock when you're going straight which is of course the issue. So, question is how straight can you drive it there and then and do you feel lucky? :)
Pull the drain plug and have a look at the diff center
I'm Irish - not as in grandpa flew over Ireland once so he's Irish - but as in birth certificate says "Belfast" as place of birth and I talk funny.
So suffice it to say I feel pretty lucky :grinpimp:
Thanks for all the answers folks - looking forward to becoming a part of the Mud community.:clap:
Good thing for me the Irish are not in fact stupid - merely ugly :hillbilly:
Still lousy form when I clearly stated I was a complete newb.
:cheers:
Good to know,
As for checking lockers I onl.y checked if they are there not tested them. If they are there you will make them work anyway so I would look at the axles and make sure you can see lockers for sure the rest, dont worry. With IH8MUd you can solve any problem :clap:
If they [lockers] are there you will make them work anyway so I would look at the axles and make sure you can see lockers for sure the rest, dont worry. With IH8MUd you can solve any problem :clap:
I completely agree. It is much easier to get them working than it is to find a nice, clean, well-maintained, low-mileage truck that has them.
-B-
Opps, didn't read the original post closely enough, though you wanted to check if it had a locker, not check if the locker still works.
Yes but you don't need to pull the diff plug to see if the diffs are elockers. You just need to see the actuator attached.
I retrofit elockers into my 91 4runner with 35's that weighed 5000 lbs plus and drove (slowly) around asphalt with the rear locked. I also engaged and disengaged the front on asphalt and drove back and forth, oscillating the steering wheel to test the locker operation.
