Temperature gauge
So my temp needle only shows 1/4 on the gauge and the heat is warm. Does everyone else’s needle go to the middle mark? I have no idea what T Stat I have, but will probably order a 195. Thanks
what are you calling the middle mark?
Mine stays at the first 1/4 line or just over a little bit ... that is the within operating temperature middle lines
Rarely goes over the 1/2 ... hotest day summer driving for 4-5 hrs then it will hit 1/2 and possibly a lip hair over
Winter time I block off the air flow to keep the heat in the engine ... that helps
Check the heater core for blockage on top of your getting not much heat
