Temp Gauge ????
Scottsdale Arizona
82 toy truck. I know things are getting old for it, so whats the likley hood that the temp gauge go bad?
Its been reading higher than normal. I did have the oms checked and it would only go bout half of what the book said it was suppose to.
Should I get external gauge?
Well with my one it was the gauge... and also my fuel gauge was iffy so changed both same time... actually have 2 temp gauges now... got an external glow shift combo with temp, boost and egt
my fuel gauge is good ill look into the aftermarket temp gauge. Any preferences on them?
I put an external temperature gauge on my 88 4Runner equipped with the 3vz. If you'd like, i can snap some pictures of it and give you an idea of what's involved. I tapped my sensor into the top of the water jacket on the upper radiator hose.
You can get metric adapters so the sender would be located in the factory location.
If you could that would be great!!
