I will let you know what he says.......
is anyone in the club familiar with electric over hydraulic trailer brakes? the gooseneck I am looking at is set up with them and acording to the seller they never worked while he had the trailer and he never fixed them because "I have been all over the country pulling it with my dually and never needed them, if you have enough truck you dont need trailer brakes" my luck does not run like that.
yup work on several
raptor liner
wre have a few kits
great stuff come ready to spry in even comes with the gun
hOW BAD IS THE overspray? I am doing this to the floor inside the cab of the dually and what does a kit run?
Mike, not sure about the sm465 but Jose has the SM420 and 1st is major granny--used it alot at GSMTR---That is until Jose would go no further--OK, you guys know I am not the most mechanical person around. So, I have some questions:
What's the best / easiest / least expensive way to get lower gearing for wheeling?
Currently, I have the SBC 350 / TLC stock 4 speed tranny / 3 speed TC (according to Brian's for sale ad when I bought the 40). I have an opportunity to buy a SM465 and as I understand it, this tranny has the low (granny) first gear. It has an AA kit to connect to a stock TC. Near as I can tell, the only other thing I should need is a GM bellhousing to make this set-up work. Is this correct or would I need anything else? Will the clutch set-up work with this? Would this be a wise move to get a lower gearing for wheeling?
I also found a guy who has an Aussie 4 speed tranny that he says would be a direct bolt-in swap for the current tranny and it has a lower 1st gear. This would be around twice the price as the SM465 option.
What about re-gearing the diffs? Would that help with slowing down 1st gear? I know this would not be a cheap option but as it is looking I am going to have to take apart the rear diff to fix a leak at some point and I want to put a locker in the front. Speaking of which, are there any other options other than ARB or automatic (Aussie, Lockright, etc) lockers? What are e-lockers and do they make them for the 40?
Sorry for all the stupid questions but I am trying to learn.
well U could B the first !OK, you guys know I am not the most mechanical person around. So, I have some questions:
