- Thread starter
- #21
Mounted the tire carrier to the Gozzard tub. I had to use four rivnuts on the top mounting bracket since I did not have rear access to the drilled holes. I used four bolts with washers on the bottom mounting bracket. My concern is the weight factor stressing the fiberglass tub and ultimately cracking. I think I will use a metal plate on the bottom to strengthen it up.
I installed the bump stop with no issue. Next up is the latch. I will have to figure out the best location and method to install the latch.
