Was able to pull up a code from the TCM as my transmission (1993 cruiser A442F, OBD1 )has been acting kinda funny at times when driving down the freeway. 2-3 times now, the torque converter has disengaged for no apparent reason (increase of approx 200 rpms).
So today, I decided to try and see if I can pull a code from the TCM and see if something came up. I didn't try this at first because I never saw the o/d light in combination meter blink on/off while the TC disengaged which would indicate a fault code. Followed the procedure on the FSM connecting the Tt & E1 terminals on the diagnostic port under the hood and sat and watched the o/d light blink, code 63.
Was reading the diagnostic on the FSM and code 63 reads as follow:
"Severed No.2 solenoid or short circuit- severed wire harness or short circuit." Then there is a HINT on bottom of page it states, : If codes 62,63,64, or 65 appear, there is an electrical malfunction in the solenoid. Causes due to mechanical failure, such as a stuck valve, will not appear."
My questions, so does this mean it is an electrical problem with the solenoid no.2? Where would the electrical be located for this solenoid or rest of them? Does all this mean that just simply replacing the solenoid might not fix/clear the code?
