Being a 1st time cruiser owner i am experiencing new things, for example issue number two is my locker switch that says RR and FR+RR, when i turn it to FR+RR the two icons showing the diagram of the drive lines and axles blink red while parked or moving, but if i place my HI and LO shifter to LOW a green icon stays on but one red icon continues to blink. I can't remember exactly but i do know if i turn the switch to RR and put it on LOW there's only one green icon on with the ABS light on and no red ones blinking, does this mean my rear locker only works while on low?
I am beginning to wonder if my ride is being driven in front wheel drive only if thats possible.
Herculz,
You should definitely consider spending some time here -->
80 Series FAQs
There is a TON of great information there that will definitely help you out with understanding your new Cruiser and can be accessed from the 80s forum - it is a "sticky" thread at the top
Here is a link on the lockers (from the FAQs) -->
Factory lockers
Basically on the lockers, unless you have done the Center Diff lock switch and Pin 7 mods (relatively cheap and very easy) then in order to lock the lockers you need to:
(1) Find a dirt road, gravel road, etc. that has some loose traction to avoid excessive drive line bind
(2) Stop the vehicle, put the tranny in neutral, shift the Tcase/Center Diff from H to L
(3) Verify via the dash lights that the Center Diff locked (The ABS light should come on noting that ABS is turned off and the icon for the center diff should light)
(4) If it doesn't lock try shifting into D and go forward a bit. Try reversing as well. You may have to shift the Center Diff from H to L and back numerous times if the Center Diff hasn't been used in awhile
(5) Once the Center Diff is locked in L then...
(6) Turn the Diff Lock switch to RR
(7) Rear diff lock icon on dash should blink and then go steady when locked
(8) Turn the Diff Lock swith to RR-FR
(9) Front diff lock icon on dash should blink and then go steady when locked
Now, if the icons just keep blinking, there are certain things you can do to try to get them to engage. Typically the lockers can be very stubborn to engage, especially if they have not been exercised on a regular basis (I try to "excercise" mine at least monthly).
First just try driving forward and backward slowly. If that doesn't work then try some slow tight turns and figure 8s. Hopefully that will do the trick
Back to your tranny issue, I would highly suggest checking the fluid. When I changed mine in my '97 LX it was pretty dark...I decided to do a complete fluid exchange (threads on MUD explain this). The fluid should be a nice bright red color. When I checked my '97 80 is was a nice bright red so I just did a drain and fill (pull the drain plug and about 4 qts will drain out, put plug back in with new crushable washer, refill to proper level, and enjoy).
HTH
