tcase input gear question
Las Vegas
What is the tooth count on the tcase input gear for the 3spd tcase versus the 4spd tcase? I am replacing my 1/75 tcase with an early 3spd case. I bought the conversion input gear but my original gear seems to have the same tooth count and spline count as the conversion gear I just bought???? Any advice is appreciated.
thanks in advance
Wanna sell it?
You just bought a gear you didn't need. The input gear for that 1/75 case is 16 internal spines in a smaller, square cut (spur) gear, which it sounds like is just what you bought. So now you have a copy. Your 1/75 case is, basically, a transition 3spd/4spd case - only available for 2 years - with a gear to fit the 4spd's 16 splines. The later cases went to the larger, helical-cut gears (I hope I have this nomenclature right!). I need an input gear to finish my 3spd case so I can use it with my 4spd trans. I am running the 4spd case since I found out I had the wrong input. Ya wanna sell one? PM me if you do, or, you can just post your response. :cool:
