TC Skid Plate...
I have the Slee and it has held up extremely well. Taken a few hits and did it's job. The few things I know of IPOR skid is that you have a greater area of protection and it replaces the cross member. If you have sliders, check to make sure the IPOR skid will work with what you have.
Both are excellent products.
Buck Buchanan
Like buck said
The IPOR unit replaces the whole crossmember and covers 3 times the amount. It also covers the trans. too
So when your sitting on just the plate the weight is transfered right to the frame rails not just the stamped steel crossmember and gives a little more surfing area when hitting the rocks .
HTHsome
the IPOR skid also protects the oil pan.
I have george's design sliders and the small little tab that is bolted down with a bolt from the crossmember had to be removed for the IPOR skid to fit. Not a big deal at all.
I love the skid. The only thing that i wish they would have done is provided counter sunk bolts for it. I know it would have raised the price, but it would be a real nice touch.
I decided before running Rubithon I had to make the same decision ... I went Slee.
IPOR is massive and I didn't feel the weight justfied the protection.
Another consideration is a boxed crossmember vs. flat steel (yes I know IPOR is 3/8" thick)
IMO a boxed crossmember would provide more strength.
The Slee plate is supported at the crossmember AND the frame rail.
Apparently IPOR has something similar at the trailing edge
Trans coverage? when I installed the Slee it was obvious that a trans plate would be very easy to fab. (although if it were really a big issue I think Christo would have made one, my crossmember had obviously been hit but the factory trans plate wasn't scratched:confused:)
FWIW:cheers:
I guess it would depend on the kind of wheeling you do
The Slee plate is supported at the crossmember AND the frame rail. The leading and trailing ends of the IPOR have no support.
negative. the trailing end does have a support brace tieing in from the frame.
on my home PC i have a picture of JZF80's rig teeter-tottering on the IPOR skid. It held up great and barely deflected. Tuff stuff IMHO.
With that said, i'm not knocking slee's plate at all. I do know a few on this board ..... Beno, where are you....that have ruined the slee plate with heavy rock crawling. I do not know anyone who has ruined the IPOR skid.
I am in the process of test-filtting a brand new crossmember/skid plate designed by Slee. I have one of, I believe, two prototype plates in the field.
It weighs 52 lbs and is a real piece of work. I just started last night and I have to work around a couple minor fitment conflicts with my Metaltech sliders.
Rubicon look out.....:lol:
the only issue that i have seen so far in my experience with my IPOR skid, is if you need to remove the driveshafts, the bolts are nearly impossible to get to.
I will be interested to see the updated slee skid.
Interested in this. Please show it to me at Rubithon.
I had no problem at all with removing or greasing my front drive shaft with the plate in place.
Man-A-Fre carries the IPOR so shipping on the west coast shouldn't be that bad.
maybe it's just the rear then. I was thinking it was both. To remove the rear i had to first remove the axle end, then push up on the shaft in order to get into the bolts.
Here's the pic as promised of jfz80's rig sitting on the IPOR skid. You can also see the rear brace that ties into the frame.
NOTE: please disregard the classy exhaust trail fix.
Hey Skillet-Did you get Slee's new skid????
Very curious what it covers and what it looks like.
So its a real likelyhood that this will not be an option for skillet for some time now.... any idea from christo on a possible date for these other guys.
lol
I have stainless wire on my exhaust system too.
:lol:
ahhh yes but do you have the coveted needlenose mod? :hillbilly:
(there are a couple other tools wired in place still......)
I heard a rumor this was in the works and so I asked Christo a month or two ago about the possibility of getting a "full size" skid before Rubiithon and he said it was unlikely.
Last week when I picked up the standard skid I asked a an unamed party (don't want him bent out of shape by using his name;)) about a prototype and he was tighter then a virgin dipped in lemon juice with any details. Gave me the impression they had no plans for production of a larger skid for the 80 (a 100 belly pan is in the works).
