TC shifters
Jackson Hole, Wy
45 lv resto
So, I am putting the 700r4 into my lv and I have used a split case TC. Thought I was going to use the AA double shifter setup, but just found out they don't make one for the split case setup...any suggestions for another supplier? I really liked the double shifter idea for hi/low and 2wd/4wd.
Thanks,
Dukes
shifters
Sorry guys I didnt respond. Georg set me up. Shifters on the way. Thanks.
lv update
I made some progress last trip to St George. Doesnt seem like much now that I look at the pictures. Seemed like more work at the time.
more updates
Wire brushed or buffed all old hardware that was covered with paint ,Temp fitting newly covered seats, installing double TC shifter from George. Also had an adaptor made for the brake booster to fit on wall of 45.
60 parts
Just finishing install of 60 axles, power steering and brake booster. This weekend driveshafts, fenders, radiator, steering wheel and laying out wiring.
And YES, I know the shackles are upside down in the picture. :) Also, using the f250 shock towers so I can put the power steering box where it is.
last pic for now
Will hopefully have more progrss pics after Thanksgiving.
I don't think your shop is big enough.. Wow.. looking great! love the seat upholstery! Killer..
shop
Wish I could take credit for the shop...it is a friend's who got me into cruisers about ten years ago. Bill Davidson. Its 3,000 ft and he only lives there in the winter. If only we could all have it so rough. Its kind of like a boat. Whats the only thing better than owning a boat?....having a friend that owns a boat! :cheers:
Pictured, you can see his lv and a longbed that came from Canada he has restored.
Thanksgiving progress
Made some progress over Thanksgiving. Insulation in all doors. A roofing product sold at Lowes.."peel and Seal". A local bodyshop recomended it. A little thinner than the high dollar stuff, but I used 3 rolls at $13/roll. Steering column in, Ford shock towers in, door hinge rubber in, new brake master with painted brake booster/pump and firewall. TC seals are in with newly cut and balanced drive shafts. Wiring is going in now.
more pics
Rear tailgate and doors with insulation. Fabricated steering column bracket for Ididit tilt steering column. Trail Candy cluster and the E-brake polished up like new.
more
Not sure if I showed pics of outboarded mounts for the springs to work with wider fj60 axles. I also got the recovered front seat bolted back into the frame...not always an easy process. We had to make a small hump under the seat to cover the additional cutout needed with the transfer case moved back from the the transmission. Seam sealed, bolted in and then hit with DupliColor bedliner in the space under the front seat. Not pictured is the newly painted rear heater.
