TBI adapter plates.
Utah
I know Mike Smythe used to make TBI adapter plates, but last I heard he hasn't made any for a whiles.
Downey makes a plate, but I think you need to buy it in a kit.
Man-A-Fre sells a plate. But it's Man-A fre.
I might make one myself, but the cost of the materials to do it will probably cost more than just buying one.
Any other options?
Thanks!
-James
Buy the one that YOU like, no matter who is selling it.
Then, if you want to reverse engineer it, get after it.
Downeys is a casting....was going to have someone make me a few, as I have alum/mag foundry in the family and then do the machine work, but can not get gov't projects in at this time, or the forseeable future.
I like the MAF piece, as it is one low profile component, but I have not been able to get the time to install the Downey stuff yet...
Didn't you just have a post up about this? I thought I saw someone's drawings out here the other day...
Good luck!
-Steve
Make your own, or buy one from Spunky... he made several when we did the TBI swap for our ME class. Trent just ordered a couple of them too... and Olly, Sully, & I still have our Smythe ones to install....
I use Man-A-Fre's, and it's pretty slick. There's one adapter out there (maybe the Smythe unit?) that rotates the TBI 90 degrees. That might be a smarter installation configuration, but keep in mind it's tall and you would not be able to use the stock air cleaner assembly. But no problems here with M-A-F's adapter.
I have more plates coming. The stock aircleaner is NOT gonna work without major fab work. The mouth on the TBI is bigger so plan on cutting the bottom out and making something. The Downey adapter is raised and rotates the TBI.
Wish I had better pics on hand, here is my solution. As far as giving up any power anywhere in the rpm range, hahahahaha. Unoticeable, The tbi is so much better than 99.5% of the carbs on f/2f Cruisers I argue that it even matters at all.
This is the prototype unit, was improved before sold. More should be available soon. The bopres are tapered using the cnc mill to meld the ports together. The hardest part is situating it so the manifold bolts aren't in either the intake opening, or the holes for the tbi mounts. I used an 8mm socket head cap screw and turned it down. No way to use the studs with a .75 billet adapter.
I have held the Downey adapter in my hand, it does turn the tbi 90 deg., so your cable is pulled from the driver fender. It clears all else with a aftermarket air cleaner.
How do you find out about purchasing options etc. for the plate?
Also, didn't you used to make SM420 plates awhile back? If you don't, who does?
Thanks for the information, ROB
Yes i made an sm420 adapter, those are gone and after maybe 100 sold, the interest dropped way off. It's not feasible for me to pursue that adapter any longer. The TBI one though is alive, just don't have any right now, I'll post up when I do.
Do you know of any "cheaper" options out there? Years ago I had the Warden's kit. I am now back into Cruisers and very happy about it.
Is Extreme Bends pretty much it?
Thanks for the help, ROB
SG, if you have one plate to send me, I'll ressurect the SM420 one....usually get them a dozen at a time, and I'll switch it to a stud-type install like my SM465 dealios are....
Nice..
I am trying to figuer out wether to put a stock 4 speed in my 72 or a SM420 (I have the ramsey PTO sitting around so I will probably stick to the 3 speed..)
s***..
The Ramsey PTO uses the stock centered output on the tcase/tranny to use the 3 speed tase on a 4 speed you need to alter the splines.. Does anyone happen to know if the ramsey unit was available for the 4 speed and if the gear is available aomewhere???
Mace, do yourself a favor and find a Toyota PTO box man, the ramsey winch heads are ok, but those drive boxes are pretty cheesy...
I do know of a source for new PTO gearboxes for SM465's and 420's if you want to go that route...
Woody- If Mike doesn't have any plates lying around, I still haven't installed the one i purchased over a year ago, and won't be installing it for at least two more months. So if Mike is down with it, and you want one to copy- lemme know. :D
works for me
see the "contact us" link and send 'er up....I'll take it to my machinist next week.
So how will the unwashed masses know that these products are available?
If there is another location, that would be cool.
Thanks, ROB
I picked up a TBI adapter plate from Mike a while back, and I must say its my favorite setup. I have worked with the Downey & several home jobbers, go with Mikes, clean, simple, and PROVEN :D
the "unwashed masses" will see the appropriate thread in the Vendor corner, same place I have kept all discussions of the SM465 plate (of which #12 just shipped today, awaiting a request for more prior to springing for another dozen...)
Which TBI do you use with Mike's adapter??? Holley Pro-jection??
