Tailpipe & muffler flange gap
Raleigh North Carolina
I just installed a used OEM muffler and tailpipe and have encountered a problem. The flanges don't sit together properly. One side is fine but the side in the pictures is clearly not. Tomorrow I'll probably install the cats and y-pipe, fire it up and check for a leak but I'm assuming it is going to leak.
What do you guys think? What are my options? Thanks.
Looks like you may have two gaskets in that joint.
one or both flanges are pitted / egged out from age & Time or rust , one might call it
they develop a Ellipse at the bottom side due to moisture condensation at the joint
That gap looks considerable. It will be annoying, loud, you will feel it in the pedal.
after dealing with exhaust joint leaks for a couple months, I would just scrap the used unit. Unless you want to spend a few hours grinding it out.
I spent probably 600 max on a dorman manifolds, genuine magna flow y pipe with cat, magna flow 2nd cat, new O2 sensors, bosal muffler and tailpipe with silencer assembly. The motor is a sewing machine now.
I took the muffler and tail pipe off this morning to check things out again. I don’t think I am going to be able to use either of these pieces. The top side of the flange on both pieces is just worn out. A trench even. Guess that is where water, dirt and grime sit, forming rust etc as someone said earlier.
The bottom of the flange looks fine.
just depends on what you want to spend honestly. I just installed the magnaflow y and had to fab a pipe from that over the frame to the muffler. I am in the middle of making a new tail pipe. both flanges on the muffler look like yours, i put in a ring gasket and 2 flange gaskets for the time being while i build. they don't leak, i had them just sitting around so may not be as convenient for you.
Wonder if I could buy or source 2 new flanges and get them welded on.
Take off the pieces and hammer the tip of the flanges back so they are away from the center. Then assemble and tighten. It will put the gaskets as the first contact point again. I did this on mine.
You mean just hammer those two edges that are separated towards one another? I'm not sure I follow you.
much better photo !
this is what i saw during my dealership TECH days from water condensation , the toyota OEM gasket is made from asbestos
this also wicks & holds moisture , hence causing the beveled holes
the bending of the flanges is caused by a new gasket and over tighten torque
Yep! That's exactly what I meant!
The seals I recently bought for mine (RockAuto) are all metal seals and are kind of a bellows type, so they seal as you compress them. They were not "hard" like the asbestos ones referred to above. I did not use Toyota brand.......
