Sporin
Site Addict
I would love some help on my taillight issue.
The Dside works fine, turn signal blinks, regular light, brake light.
The Pside works for regular light & brake light but doesn't blink. I thought this was a slam dunk when I opened it up since 1 of the 4 green wires was cut, so I fixed that but no dice. Also it doesn't seem nearly as bright as the other side in any position.
I pulled the steering wheel off and cleaned up the switch ball thingy and put in dialectic grease. Tee fuses are all fine and clean. I unplugged the wire going to the flasher unit under the dash and cleaned it, dialectic greased and reattached firmly.
Still nothing when the signal stock goes up, I get 1 click/blink then it just stops.
Thoughts? Where should I look next? Any help would be appreciated.
