- Thread starter
- #21
With the front driveshaft off and center diff unlocked the vehicle will go but you MUST rev the motor so the VC will lock, then you can drive till you stop.
Chuck. With the front driveshaft off and in drive (parking brake on) have someone look at the front output shaft on t-case and see if its spinning. It should.
When the center diff is locked (low range) the front output shaft wont spin.
Another was to check is turn off motor and put the t-case in N and tranny in N. With the front driveshaft off or front end off the ground. Turn the driveshaft/front output shaft. It should turn with resistance.
I hope your VC is not locked up. But the fork that locks the center diff could be stuck.
