T-case output shaft
Montreal
I was inspecting under my truck yesterday and notice when i took the TC output flange and shook it, it was a bit loose, more the rear one then the front. At first i thought my bearing must be done. But i then realise, by looking the manual the ouput shaft has spline, am i right assuming this loose is mostlikely the spline and nothing to worry about? There is no trace of oil anywhere nere the rear output shaft..at least
output shafts don't have play or not enough for you to notice. If it is up and down play then it is bearings. WHat condition is the gear oil? You can add shims to the rear output assembly and it will tighten it up. Though if it has gotten loose then the bearings are worn.
Getting the TC on the floor is what 1 hours job? But how should it take to overall it if brought to someone who know what he is doing?
I have that anying high putch sound and i bet it is from the TC. You know how sound a racing dog box with straight cut gear? I constantly have that high pitch sound over 40 mph.
Something like, but obviously not that bad
http://www.ericleblanc.com/files/ericleblanc/sound.wav
