Synthetics
Any quality oil is FINE for the 1FZ.
Shell Rotella 15w40
Delo 15w40
Delvac 15w40
All are fine and good to at least 5k mile intervals.
I have gone as high as 7k intervals with each of the above oils and an OEM filter.
As was discussed easily a decade ago, the 1FZ is very delicate on oils.
Intervals can easily be extended.
It could be paranoia. I still change the oil (synthetic) at 5000 miles. When I had different cars in the past using dyno oil, the interval was 3000 miles.
Decades of doing this thing has left deep scars on my brain. I can't see how I can extend that period, no matter what I read.
I also hate touching the redline.
Crazy stuff.
As someone here said it recently, this car will probably die of a different cause, other than engine failure, but why take the chance, right?
I totally agree with that member (sorry, can't remember where I read it, in what post and who wrote it... one of today's posts)...
Let's see beer, whiskey, wine (started really early, my wife is at fault, she popped the first bottle open around 4PM.
Crazy stuff.
This is getting old
Refresh and refill your mind with new oil and filter data. I find reading about oil and filter technology while drinking coffee quite satisfying. On the positive side I know what you wish to know and young chick's dig my OCI. :flipoff2:
I can't do that.
I've wasted 30 min trying to figure out what group number my battery is, where I got it from, where the damn receipt is.
I was positive I got it from Home Depot, but it turns out Pep Boys got my money. It drove me nuts, till I got it all figured out.
Now you want me to start reading about oil and change my mind, hell no. I'm on strike.
I had to go back a few years worth of posts on a different forum to find out about my battery. Damn. 5000 mile tops on my oil. There, I said it. Not a mile over.
Can't go wrong with that... but hear me out.
If you check the oil level, and it hasn't changed without topping up, and if the color is the same as new oil, why not wait another 1000 miles and re-inspect?
Most healthy engines can easily go with extended oil change intervals. Our engines hold 2 gallons of oil, it's not a corolla that holds half of that. Double the amount of oil, should, in my mind, last twice as long, because each drop of oil does half the work?
I read on this forum, years ago (perhaps a decade, maybe more) that some guy did blackstone lab UOA at ~2k intervals. At ~13k on dino oil, he couldn't run it any longer so he changed oil and filter, and sent in his final sample for this experiment. The results? Keep running the oil, it's fine. After 13,000 miles, on dino oil. Synthetics will hold up even better.
Somebody find the thread please...
I can't do that.
Let it rest
Thanks for your input.
My car calls for Shell special formula, prior to Shell they required a special Castrol oil, which is no longer available.
The way I read your post, it seems like those two companies do not produce really high quality oils. Did I get that right?
What is your take on Rotella T6? They recently altered their formula, less zinc content I believe.
Shell and Castrol make fine oil but they are guilty of misinformation as allowed by the USA legal system. Their full synthetic may or may not be group 4 base stock. Very likely it is group 3 mineral oil.
There are too many folks running rotella with no history of engine failure to say it is a crap oil.
As for changes in oil formulations, those are going to happen from time to time. Usually they come as a result of an industry approved change due to a failure found in the field or EPA issue.
Every oil standard has an board made up of all the major oil companies and OEMs. If the OEMs can show that the oil is the cause of failures in the engine or EPA devices they will call for a re formulation.
GM did so on passenger cars due to catalytic converters being poisoned by higher mile cars with bad rings. They were required to warrant the work. So they decided to request a change the API formula. It was approved and the offending wear inhibitors were removed.
My old GFs grandfather was a Lubrizol executive back in the day and he said all oil is the same except for the additive packages they put into the oils.
Truth. There are only a few base oil refineries in the USA. They supply all the base stocks that are available.
As a made up example - It may say Mobil on the bottle but citgo was on the tanker truck that delivered that oil to the bottler and blended it to Mobil's specifications.
They were claiming EPA rules mandating the change. But, I think the change should be universally applied, not to just one company. Unless they were out of compliance to begin with.
Of course I have no idea if T6 is fully synthetic or "synthetic" group 3.
I cannot even attest to its superior capability in lubricating the engine more than other oils, I have no means of making and supporting such a claim.
The engine in my car was rebuilt some 30k miles ago and the mechanic recommended T6. The previous owner ran T6 in it, so do I since I got it. Everything I say about T6 is purely subjective without any hard evidence one way or another.
In my case, I really don't think it matters all that much if I use group 3, or 4 or alien synthetic technology group 51. I change it more often than what everybody advises for a regular interval. I think that's the key here, regular oil changes not necessarily using the top brand. With that said, I would not use Autozone brand oil just because it is cheap and I can change it frequently. I have no idea who makes it (it could be a brand name sending Autozone the leftovers at a great discount... I don't know).
I had, in the past, a close relationship with one oil brand and then with another. Probably purely based on the number of commercials on tv and the bottle design and logo. It was all mineral oil for old cars (1970 VW, 1986 VW, 1987 Honda, 1990 VW, 1996 Honda...). Penzoil and Valvoline were my favorite brands.
When they said Zinc, did they mean ZDDP? Because the EPA is pushing that out of just about everything.
Not sure if this is the post you were thinking of but it's the one I remember.
should i stick to 10w30 or go to 10w40? Post 23.
I guess that's the proper name for it.
They took it down by about 100 points, whatever those units are.
Currently M1 has a higher content.
Now that my 96 FZJ80 burns a quart (of Mobil 1 10W-40) every 1200 miles and knowing I'm topping off the oil
more frequently (freshening up the additive package) I generally change it out once a year no matter the mileage.
The newer Purolator Boss filter seems to have good specs and is designed for a long life so I've switched to using those recently. The Blackstone engine oil analysis comes back good. FWIW
Anyone care to share a report on what a 2F engine oil report looks like at 5K miles?
@brockdeck if your looking to save money it will probably be cheaper in the long run to use Mobil 1 synthetic. It costs me about $50 a vehicle if I buy from Walmart to do Mobil 1 0w-30 and their filter. They guarantee 15k miles or 1 year of protection. Which means that the oil is most likely good for much longer than that. The point is I changed all of my rigs in October of this year, they will all get changed again in October of next year !
Also, of some interest; my father is the head mechanic for a local oil and fuel delivery company. He recently had an interesting conversation with a representative of Detroit Diesel. The short of it is they recommend 35,000 mile oil changes for "severe duty" engines. That wasn't a typo either. So that's the maximum under the worst conditions. For long haul trucking that number bumps to 60,000 miles. Granted lots of these trucks will have bypass filtering. The takeaway though, is that the oil will handle it if the filter is doing its job.
I'm thinking next year when oil change season is upon us, I will order a couple of kits from Blackstone Labs and get some real data to look at. Until then I will just track mileage and consumption.
Costco sells DELO and Mobil 1 engine oil in the viscosity that my vehicles take.
I am running DELO in my Cruiser currently.
Mhm... I'll go with anything made by Chevron (Havoline, URSA or Delo400).
For some reason I prefer conventional oil since I have seen it running on my B engine for 24 years and still running good (replaced rings past year only).
I will switch my 80 to synthetics soon, some people have told me it bad things like deposits on the engine on the long run but I don't know... I will give it a try and see how it goes.
Over the road trucks run Dino oils this long as well. Cummins does not endorse or recommend synthetic oil. M1’s claims came out back when most people were still changing oil every 3,000 miles so you can imagine the hype that developed back then.
My dodge/Cummins owners manual calls for oil changes at 7500 under severe duty or 15k in a perfect world. I don’t operate strictly in either maintenance plan but I do a lot of in town driving with an average speed of 30mph as calculated using the built in hour meter. Changing my Delo 400 15-40 at 10k (about one year) or running out to 15k gets me about the same comments from Boackstone - “you could run it longer”. Running oil longer dictates the use of a high quality filter.
Isn't the oil really dark when you change it? I know diesels run a little more dirty and that's the reason I prefer to change mine at 1/2 of the required interval.
The oil turns black quickly. That’s just soot. The soot is kept in suspension by the oil and poses no real danger other than being able to raise viscosity numbers if let go too long.
I used to be a member of the Turbo Diesel Registry (a dodge/Cummins thing). One of the editor did a test where he ran Delo 400 and sent samples to blackstone every 5k or something like that. At 20k Blackstone told him he could continue running the oil but his old thinking could not allow him to go any further on that oil.
I have settled on a 10k OCI on the dodge, it’s easy to remember. This usually puts the oil at 265 hours and one year. Oil does not know or care how long it has been in service. Most equipment owners/operators are going 350-400 hours on oil.
I haven’t been into the 80 series long enough to settle on an OCI yet as I have had three of them in 4 years therefor haven’t driven any one of them enough to make a dertermination. Between 5k and 10k seems to be popular here on Mud. But, summer wheeling can be very dusty. Analysis doesn’t lie.
