syncro gear
I got a 3spd and when i down shift from 2nd to 1st while moving, even a mile or 2 an hour it grinds. was thinking if i replace the sincro gears it would solve the problem. Any deep thoughts?
nope, nothing is going to fix that.
1st gear in the 3speeds are NOT synched.
best way to "fix" that would be to swap a 4speed tranny in. it's pretty much a bolt in swap.
If you think that you really need to drop it into first while moving, learn to "double clutch" it. Move the lever from second into neutral, let out the clutch, rev it up to the same speed the engine would be turning in first gear, step on the clutch again and then drop it into first. No grinding and it doesn't cost anything.
