Sylvania Silver Star
I've never heard of this upgrad before, what is this JD bulb supposed to be for? Damnit now I got that "John Deere Green" song stuck in my head too! :doh:
John Deere HIR bulb info
The JD bulbs are just a cheap source for Toshiba HIR bulb, to be used in the low beams. JD does not have the replacement for the high beam.
Sylvania SilverStar Ultra
I have the Sylvania SilverStar Ultras for hi and lo. Made in the US. Rumour has it there was an issue with an overseas plant :confused: with some of their bulbs. :rolleyes:
I recently replaced what I believe were gold Sylvania's (in there for many years).. and installed Slee Harness
http://www.sylvania.com/AboutUs/Pressxpress/Pressnews/SilverStarUltra.htm
I have minimal night vision, they do iluminate the night, but not like my wife's Nissan HIDs, but almost as bright as my Tacoma (9 yrs jr.).
You's gotta see for yourself... :eek: :grinpimp:
I've been using Silver Stars in both beams with the Slee harness for about three years. I had one low beam fail in that time, so I replaced the pair (kept the good one as a spare). I won't use any other light for city driving. I don't care what the statistics say about wavelength or output - the light just flat suits me perfectly. I just like the way the road looks. IMHO it's much better than standard halogen.
I do have fog lights that I use as DRLs in dim weather, rather than burning my expensive low beams. That has helped with the life span of the Silver Stars.
I considered the HIRs and will probably install a set in my high beams if my SSs ever go out, but I think they would be too bright for regular city driving on low beam with a lifted 4x4. I don't like ticking off oncoming drivers.
I'm going to put SSs in my new RAV4 right away, I like them so much.
They HIRs not too bright for regular city driving, which is what I mostly drive. They don't change the light pattern, and I've not gotten high beamed by anyone yet. I just made sure they were properly aimed.
Yes, the HIRs, mentioned in the lighting section of the FAQ.
Damn that FAQ! I allways seem to miss whats most obvious :D
Thanks firetruck :cheers:
wait a minute, im only seeing HIRs refrenced for low beams in the FAQ. Im looking for some retina burning highs. Does anyone have a brand or model? part number even?
It's in there last time I looked. 9012 and 9011 are the HIRs, can't remember which one is low and which one is high off hand. You can get them from Daniel Stern or the other vendor mentioned in the FAQ.
9005= 9011 = high beam
9006 = 9012 = low beam
Note not all 9011 and 9012 bulbs are HIR bulbs. They must have the unique globe shape with the coating. Some of the 9011 bulbs used in newer cars are normal halagen bulbs.
Cary,
What bulbs do you run on low beam?
SS
After buying and ititial set for low and high beams, then replacing 1 low beam 6 months later, then the other 2 weeks later, then back to the other 5 months later.The first set seemed to fail after parking on 2 of the coldest nights of the winter. They worked when I parked, then when I started up in the morning, they broke the filament.
I swtiched back to "regular" bulbs. It was getting too expensive.
Which bulbs are you talking about? Silverstars? If the HIR's are blowing out like this, you either have a voltage regulator problem or are touching the glass when you install them.
FWIW I've had good luck with the PIAA Star White bulbs. They don't have the silly blue frost on the bulb. They were fairly cheap and have held up over the last year without issue. According to my old and crusty eyes, they work well.
I use standard low beams as I don't see the logic in blinding oncoming traffic. Only my high beam bulbs were replaced.
